HOW TO: DIY Custom Interior Project - **NO56K**"
#404
#405
Re: HOW TO: DIY Custom Interior Project - **NO56K**"
This car is actually about to be for sale the end of this week. Interior is the same. Only changes are no more Red Recaros (Si Fronts instead) and the Custom rear seats are installed. Gonna park her on one of the main roads by my house and see what I can get for her.
#406
Subscribed! Im in the midst of removing dash to try and get at aome rust that is in the top left corener of my dash, still unsure if i will get at it once dash is removed, the rust hole is behind the wiring and relays mounted on drivers side of dash.
OP-- some feedback would be greatly appreciated since you have seen the car with the dash removed. Do you think i will gain access to this from the inside with the dash removed?? Here is a link to the thread i have been writing about this rust problem and water leak.....
https://honda-tech.com/paint-body-84...ution-3272753/
#407
#408
Removing the dash will get you a better view to what you need to remove to take care of the rust. The main relay and wiring is all attached to the frame of the dashboard. Sounds like once dash is off your going to have to remove some wiring too so you can get at whatever rust is forming.
Good luck
Good luck
#411
#412
Yea I plastic diped the inside of my eg black but the part of the doorcards exposed to the sun kind of gets tacky from heat not enough to melt off colder conditions will be fine has lasted for about 1 year so far but the rest of the trim are no probes
