C129 92-95 VX - Any connector on the 6th gen?
Old 11-04-2019, 07:46 PM
Hysterically Calm
TomCat39's Avatar
Default C129 92-95 VX - Any connector on the 6th gen?
Greetings yall.
So C129 is a Grey 6pin connector that only resides on the VX model of the 5 generation civics. It's not used anywhere else in the car unlike most ever other connector in the car. So it's a one off connector that only comes on a rare trim level for the 5th generation civics.
Below view #1 is the ETM manual pictogram for the connector. Does anyone have the ETM for the 6th gen? If you do can you tell me if you have the same looking connector in your view list? If so can you tell me what connectors correspond?
I'm hoping Honda utilized that particular connector more regularly in the next generation of civics. I can find mates for every other connector in the car of the 5th gens easily, just not that one.
I'd like to be able to make use of my salvage yard instead of having to order brand new for 1 connector.
Old 11-07-2019, 07:21 PM
Oh look, I can change this
deschlong's Avatar
Default Re: C129 92-95 VX - Any connector on the 6th gen?
If you had a pic of the actual connector instead of the diagram from the ETM, I think that would be more helpful.
Old 11-08-2019, 02:35 PM
Relic1's Avatar
the pin layout is one thing, the connector keying is another.
which side do you need? Mail pins or female pins? I may have something yet from my Z1.
Old 11-08-2019, 02:54 PM
Fish Twig
tony_2018's Avatar
Do you need a male or female? Cuz I looked at my radiator harness and saw a 6 pin male.
Old 11-08-2019, 04:00 PM
spAdam's Avatar
What is the connector/location? If it’s a Sumi connector they are so cheap that it’s not even worth the hunt.
Old 11-08-2019, 04:19 PM
Global Moderator
tech8's Avatar
Originally Posted by TomCat39
Greetings yall.
It is connector view 1. Connector C129 is a female side connector; so the terminal pin numbering is from the wire side.
Connector C129 goes to the ECM.
1 – Yellow Black – Reference voltage (connects to EGR valve lift sensor)
4 - Wht/Blk – EGR valve lift sensor input (connects to EGR valve lift sensor)
2 – Wht/Blu- Sensor Input (connects to heated O2 sensor)
3 – Blu/Yel – Heater Control (connects to heated O2 sensor)
5 – Blu/Grn – Sensor ground (connects to heated O2 sensor)
6 – Orn/Blu – Sensor input (connects to heated O2 sensor)
Old 11-08-2019, 05:11 PM
Hysterically Calm
TomCat39's Avatar
I would need the male side.
I understand buying new is not expensive but it's the wait for shipping etc. I'm going to my local salvage yard this weekend.
The 8th gen seems to have the similiar shaped view 6 pin on their EGR but it's the female side. I suspect Honda kept this round grey plug with narrow connect tab for their EGR's and later on they connected directly to the EGR itself while on the VX it's the engine harness (male if I recall) to tower (female).
Picture of the connector I am hoping to find locally this weekend:
The female side (tower plug) I would like to connect into:
I have the ETM, I know what wires are for what and colors etc. I am looking to make a conversion harness at the shock tower. This will save me from having to depin and repin tower connectors to accept a non VX engine for a time.
Old 11-08-2019, 05:52 PM
spAdam's Avatar
https://www.corsa-technic.com/item.p...ategory_id=113
Old 11-08-2019, 07:50 PM
Hysterically Calm
TomCat39's Avatar
Oh, that's nice, they mention where they know it's used, That's awesome! Thank you spAdam! Quite helpful. If I don't have luck I will order from them and deal with the shipping wait times as possible duty/import taxes/delays.
Old 11-08-2019, 09:13 PM
Fish Twig
tony_2018's Avatar
You should be able to find them civics in the engine bay.
Old 11-08-2019, 09:14 PM
Fish Twig
tony_2018's Avatar
Nice!!
Old 11-09-2019, 06:07 AM
Hysterically Calm
TomCat39's Avatar
@spAdam what is your secret to get the black page where they provided application use? I have clicked every link and even used the search bar with part number and have not been able to find the black page you provided the snippet of.
Whats your secret?
Old 11-09-2019, 07:39 AM
spAdam's Avatar
Lol that’s a different website. I like Corsa because they give you the manufacturer’s part numbers, but http://www.cycleterminal.com has lots of good descriptions
Old 11-10-2019, 03:06 PM
Hysterically Calm
TomCat39's Avatar
I can confirm this connector is used on at least the D16Y8 of the 96-00. I found it on a 97 Civic that already had a bunch of crap ripped off so this part of the harness was hanging up front. I grabbed it and tested it on a VX that I pulled the motor and trans from for a steal (even though I learned the motor knocks) and it slid into the female flawlessly.
So this rare connector for the 5th gen is a bit more common I think in the 6th gen. I'm just not sure where or what it is a connection for in the 6th gens as I don't have the ETM to see.
Actually looking at this thread by HondaPartsHero, It looks like it was for an EGR valve for a D16Y5. I saw D16Y on the block and didn't want to clean off the grease off the plate and assumed it was Y8 with the vtec solenoid. Now I think it was a vtec-e solenoid.
Last edited by TomCat39; 11-11-2019 at 02:46 PM. Reason: Informational correction.
grumblemarc
Suspension & Brakes
03-25-2013 09:13 PM
AThiker
05-30-2002 04:50 PM
Lookincrazy
01-04-2002 12:23 PM
gsx0r
11
10-19-2001 06:07 AM
Quick Reply: C129 92-95 VX - Any connector on the 6th gen?
