High HC ppm Reading
Old 12-02-2010, 12:26 PM
Jay123's Avatar
Icon2 High HC ppm Reading
I failed my inspection test only because my Hc ppm reading was too high and i dont understand what it is when i passed everything else............
Old 12-02-2010, 12:41 PM
DVDr's Avatar
Default Re: High HC ppm Reading
do a search for High Hydro carbon output and what causes it.
The main reason though , is not complete combustion, wich can result from poor ignition system ( wires,plugs, car, rotor ).
Did you change those ?
Old 12-02-2010, 01:50 PM
Former User's Avatar
^This
And also check the ignition timing with a timing gun.
Old 12-02-2010, 02:09 PM
93egSLEEPER's Avatar
Do you have a cat on the car?
Old 12-03-2010, 04:23 PM
ddd4114's Avatar
If your CO readings are normal, the engine is misfiring. The hydrocarbon reading is high because unburnt fuel is passing through the engine.
As stated, check your plugs, wires, cap, and rotor. It wouldn't hurt to check the ignition coil too.
Also, it would be good to post your engine modifications for this sort of problem.
Old 12-04-2010, 10:00 AM
If your not running a cat, it can cause your motor to let unburned chemicals exit out of the exhaust which will cause you to fail. I had the same problem with my motor, no cat, high HC levels. Threw a cat on it and passed with flying colors. Just that little bit of extra heat makes a world of difference.
Old 01-04-2011, 06:06 PM
ehLAaay's Avatar
lol i failed my test twice today because my HC PPM was high also, first test at 10BTDC my HC & (CO) reading at 15mph max 96 (0.59), ave 38 (0.14), measured 164 (0.58) at 25mph max 79 (0.51), ave 30 (0.11), measured 119 (0.27), now on my second test i adjusted the timing to 14BTDC my HC & (CO) reading at 15mph max 96 (0.59), ave 38 (0.14), measured 115 (0.64) at 25mph max 79 (0.51), ave 30 (0.11), measured 189 (0.59), now it helped my HC a bit but it screwed up my CO, the smog technician told me to adjust my timing higher to 16BTDC, what should i do? stock 1992 Honda Civic CX (Canadian model) D15B7 but i've got an AEM smog legal intake on there, the filter is kinda dirty i'm thinking replacing that should help, along with adjusting the timing, any advice would be much appreciated
Old 01-04-2011, 06:11 PM
ddd4114's Avatar
Sorry, but that's probably one of the most convoluted posts I've ever read.
Make your own thread in which you CLEARLY describe the problem.
EG92DX
08-18-2012 08:19 AM
tour de france turbo
09-13-2005 03:09 PM
Splangtastic
06-19-2003 01:30 PM
loki2323
06-11-2002 02:42 PM
clockworks
06-28-2001 06:08 PM
Quick Reply: High HC ppm Reading
