HELP!!Squealing Noise When I Start My Car?
Old 12-14-2007, 02:00 PM
jdmstockeg6's Avatar
Default HELP!!Squealing Noise When I Start My Car?
Hi, everytime i start my car, 1993 honda civic with a b16 swap, the area around the alternator squeals for about 1-3 seconds, and sometimes longer. sometimes, at the start it squeals then stops but when i drive it squeals again, so i have to hit the gas then it stops.
only about 5% of times that i have started the car withouth it squealing. lol
what could be the problems? loose or tight belts? need to change my alternator? any other suggestions? thanks!
Modified by jdmstockeg6 at 3:12 PM 12/14/2007
Old 12-14-2007, 02:28 PM
Budget Racer's Avatar
Default Re: HELP!!Squealing Noise When I Start My Car? (jdmstockeg6)
loosen your belt. clean the pulleys, then make the belts tighter. But not over tight.
Old 12-14-2007, 02:30 PM
archuletac's Avatar
belt dressing,but the belt is more than likely loose to some degree.
Old 12-14-2007, 10:44 PM
McDonagh's Avatar
Belts that aren't OEM usually make that sound
Old 12-14-2007, 10:46 PM
fmrprojects's Avatar
Default Re: HELP!!Squealing Noise When I Start My Car? (McDonagh)
i use aftermarket and oem they are the same ****. squealing belts means that they are loose. i've seen this problem many of times
Old 12-14-2007, 10:51 PM
mastakmk's Avatar
Default Re: HELP!!Squealing Noise When I Start My Car? (fmrprojects)
make sure you have the bottom bolt in... when i first installed my motor way back when.. i lost a bolt driving.. went back picked it up had it in the car forever not knowing what it went to till my belts started going crazy and kept loosening. soo check make sure belts are tight. and both bolts are installed and snug. also they have a spray ... to clean it. may help.
Old 12-21-2007, 04:58 PM
mxdengler's Avatar
loose belt.. all you have to do is tighten it
Old 12-21-2007, 05:09 PM
Unceasing Measure
Archidictus's Avatar
Default Re: (mxdengler)
Hey guys,
My car's making a noise from a specific place and it seems like this specific problem but I'm too lazy to check and see if I'm right and/or take five minutes to fix it. Does anyone want to use their mental-abilities to fix it from their house so I don't have to stop jerking off? It would really be best if you could bring me a beer too.
Thanks.
Go check your damn car. Touch the belt. If it's loose, tighten it, if it's ripped, replace it.
Old 12-21-2007, 05:22 PM
ke98248's Avatar
Default Re: (Archidictus)
F@llon58
06-01-2017 07:39 AM
gohonda
10-28-2009 10:16 AM
d8168055
05-18-2004 02:07 PM
xstalkrx
10-24-2003 03:57 PM
B18C-RnVA
05-18-2002 02:06 PM
Quick Reply: HELP!!Squealing Noise When I Start My Car?
