Help: Odometer stopped reading.
Old 06-14-2007, 10:36 AM
D'PEXi's Avatar
Default Help: Odometer stopped reading.
Hey guys my odometer stopped reading.
Is there any way I can fix this?
Or would the only solution be to get a new cluster?
Opinions please. Thanks!
Old 06-14-2007, 10:53 AM
sleepiieex215's Avatar
Try cleaning your VSS
Old 06-14-2007, 10:56 AM
instructor74's Avatar
Default Re: (sleepiieex215)
good for you now your cars mileage will never change just fix it when you resell it jkd
What car? does it have digital odometer or mechanical? everything else work on the cluster?
Old 06-14-2007, 10:58 AM
mike1114's Avatar
I give it to you step by step.
1. First go to the upper right hand corner of this chat forum and click on the red SEARCH button. From there, search, don't forget to sometimes try archived material as well. 9-10 doctors would reccommend doing this before EVER asking a question.
2. Once done searching you'll then know its either your VSS is dirty or went bad. If it is not either of these two, your cluster is bad, but the problem will for sure be your VSS.
3. clean or replace VSS (junkyards are your friends if you need one)
Old 06-14-2007, 01:56 PM
Agent_EM1's Avatar
Default Re: (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">I give it to you step by step.
3. clean or replace VSS (junkyards are your friends if you need one)</TD></TR></TABLE>
The best advice ever
Old 06-14-2007, 01:59 PM
schardbody's Avatar
is the check engine light on??? if not then its not the VSS. if the VSS signal isnt present the ECU will spit a code and the check engine light will come on.
nukem384
11-11-2010 07:33 AM
Kasta_JayDeeEm
04-30-2010 09:48 AM
xxdown2businessxx
03-02-2008 04:20 AM
rcantu
07-09-2006 05:58 PM
NetBoy541
09-29-2005 05:59 PM
Quick Reply: Help: Odometer stopped reading.
