seafoam ?
seafoam ?
where can i buy this so called SEAFOAM? Autozone,advance autoparts, where? PRICE? and can i feed it through my Vacuum hose on my Intake manifold? links on where its done on the intake manifold?
Re: (crazyc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri »</TD></TR><TR><TD CLASS="quote">Honda-Tech.com » Search » 165 topics found
» Search Results
Your search for seafoam returned 165 results.</TD></TR></TABLE>
So while we're being ******** about everything...
"> "Search n00b." If you tell someone to search, you had better provide them with a helpful link."
- Source '92-00 Civic / Del Sol Rules and Guidelines
» Search Results
Re: (Syndacate)
To answer your question directly, Advanced Auto, AutoZone should both carry it, and it's anywhere from 4 to 6 dollars a can. Most people put it through their PCV or brake booster line.
Re: (dangthemang)
most auto stores sell it and even some hardware stores have it. its only about $5. when i did it i put some in the gas tank and some thru the fuel pressure regulator. worked great, a month later and car still idles and runs like new.
Re: (civexspeedy)
Do some research before you go pouring this into your motor. It can improve certain things, however, it can also hurt your motor. Sometimes, it can cause your seals to worsen if they're already pretty bad. However, it goes a good job to clean out build-up.
