Help Need 1992-1995 VSS Speed Sensor Wiring
Old 04-16-2008, 01:44 PM
xalents23's Avatar
Default Help Need 1992-1995 VSS Speed Sensor Wiring
I need the wiring info on a 1992 Civic SI 3Dr VSS Speed Sensor. If anyone has a picture or diagram showing what wires are what and where they go on the VSS speed sensor. That would be greatly appreciated. I don't have the wire harness that connects to the electronic VSS speed sensor. And don't want to connect the VSS to the wrong wires and damage it. I am doing a gauge cluster swap that is why I need this info.
Old 04-16-2008, 02:04 PM
mudd_butt's Avatar
Default Re: Help Need 1992-1995 VSS Speed Sensor Wiring (xalents23)
the vss plug is like a square it onley fits the vss plug wont fit other
Old 04-16-2008, 02:24 PM
xalents23's Avatar
Default Re: Help Need 1992-1995 VSS Speed Sensor Wiring (mudd_butt)
I need the wiring info. As in which wire goes where on the VSS. As, I do not have the connector end or wiring harness. I know there are three wires power, ground, and VSS signal. I need to know which wire goes where. I have attached a picture of the VSS speed sensor below.
Modified by xalents23 at 3:35 PM 4/16/2008
Old 06-03-2008, 06:41 PM
95dc2teg's Avatar
what color are the wires that plug into the speed sensor??
Old 06-03-2008, 07:32 PM
MIsterE533's Avatar
Default Re: Help Need 1992-1995 VSS Speed Sensor Wiring (95dc2teg)
alrighty, here it is. power wire solid yellow sensor wire yellow blue and ground is black. wire your ground to your water jacket ground or other suitable ground, water jacket through the loom is easiest, well through the loom no, but its the oe ground for that sensor. find a power connector and your ecu pinout is on the forum here's a picture as well.
Old 06-03-2008, 07:59 PM
95dc2teg's Avatar
Default Re: Help Need 1992-1995 VSS Speed Sensor Wiring (MIsterE533)
thanks man i appreciate it!
FrontwheelENT
01-08-2012 03:44 PM
LaEzEnT
12-15-2008 07:50 PM
ruiner17
08-17-2004 06:24 AM
HATCHMO92
08-08-2004 02:09 PM
Quick Reply: Help Need 1992-1995 VSS Speed Sensor Wiring
