HELP HELP AFTER DISTRIBUTOR O-RING REPLACEMENT!!!
Old 03-01-2007, 09:50 AM
New User
warchieft2k's Avatar
Default HELP HELP AFTER DISTRIBUTOR O-RING REPLACEMENT!!!
I replaced my o-ring on the distributor and now my car does not start. the started spins and nothing!!!
I think i might have turn the flapby misstake and now my timing if offf....
I got a 96 civic coupe ex...
how do i fix my timing??????
Thanks
Carlos
Old 03-01-2007, 09:57 AM
Unceasing Measure
Archidictus's Avatar
Default Re: HELP HELP AFTER DISTRIBUTOR O-RING REPLACEMENT!!! (warchieft2k)
Your distributor only goes on one way. You can't screw up the timing at the distributor unless you damage something. Are your plug wires in the right order?
Old 03-01-2007, 09:59 AM
New User
Default Re: HELP HELP AFTER DISTRIBUTOR O-RING REPLACEMENT!!! (Archidictus)
i didnot remove any wires... ?!?!?!
Old 03-01-2007, 11:00 AM
New User
nevermind, i installed the flaps 180 degress wrong... its fixed... i was scared shitless...
Thanks anyways...
Old 03-01-2007, 11:02 AM
-JSpecEk*9-'s Avatar
Old 03-01-2007, 11:04 AM
Jakester9500's Avatar
how did you put it in on 180 degrees off? it isn't supposed to fit like that.
Old 03-01-2007, 11:16 AM
onesikdb8's Avatar
Default Re: (Jakester9500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jakester9500 &raquo;</TD></TR><TR><TD CLASS="quote">how did you put it in on 180 degrees off? it isn't supposed to fit like that.</TD></TR></TABLE>
I'd like to know also...It definitely won't fit 180 off.
Old 03-01-2007, 11:18 AM
Unceasing Measure
He probably forced it with the bolts until it almost fit. He's lucky he didn't **** anything up.
mgold
03-05-2012 06:42 AM
taguchi09
06-11-2011 04:52 PM
irishgod247
03-13-2007 10:35 AM
dopefeen
16
03-12-2007 10:34 AM
zerogravitycrx
05-10-2006 01:43 AM
Quick Reply: HELP HELP AFTER DISTRIBUTOR O-RING REPLACEMENT!!!
