Help with EG-Kswap(electrical). ktuned conv harnees.
Old 03-05-2017, 02:37 PM
B_Swapped93's Avatar
Default Help with EG-Kswap(electrical). ktuned conv harnees.
94 eg8/k-pro/k20a2
I'm stuck on finding/hooking up 2 wires and ID-ing a mystery plug?. The fuel pump relay, a wire comes off my conversion harness and is supposed to go to the "fuel pump relay wiring"(their words). And the ELD, I can't remember if the eg has an ELD, ktuned says "skip it if your vehicle does not have one", if it does it's in the fuse box IIRC, how will I be able to hook up to it?.
Old 03-06-2017, 08:54 AM
Default Re: Help with EG-Kswap(electrical). ktuned conv harnees.
bump.
Old 03-06-2017, 10:22 AM
Fish Twig
tony_2018's Avatar
ELD is located in the engine bay fusebox. Main relay is near the dash fusebox.
Old 03-06-2017, 11:23 AM
Forgot it was called the main relay, vs fuel pump relay. I'll find the pinout for it, but it doesn't say weather to tap into it or cut and splice. As for the ELD, is it tap or cut and splice. I can find the pinput but weather or not they're tap in or splice is what I need to know.
Old 03-06-2017, 11:39 AM
Fish Twig
tony_2018's Avatar
You need to connect them, splice them, into the ecu harness. So the ELD connects to D10 of the ecu plug and the Fuel Pump connects to both A7/A8.
Old 03-06-2017, 02:45 PM
Ok, I got confused and thought I had to somehow tap into the main relay and bust open the fuse box and find the eld. I'm guessing you just connect a7/a8 then connect them to the conversion harness, hoping someone who has used this and done it can confirm.. I'd still like to know what that mystery plug is.
Thank you for your help Tony.
Old 03-06-2017, 03:00 PM
Fish Twig
tony_2018's Avatar
np, gl
Old 03-06-2017, 04:25 PM
mk378's Avatar
The ELD wire should already be routed from the underhood fuse box to the OBD1 ECU location. You shouldn't have to mess around in the fuse box at all.
Your second picture is the socket for an OBDII scanner. Bolt it up somewhere under the dash so you can plug in a scanner.
Old 03-06-2017, 04:45 PM
D10 on the ECU harness/plug for the ELD. i'll have to see if my plug fits over it, iirc the bracket blocks a plug from sliding over. Strange they'd incorporate that into an obd1 car, granted this harness if for the DC also, which went into the obd2 years so might be null foe me. I've got k-pro thankfully.
Thanks man.
Old 03-06-2017, 05:11 PM
Seagull Management
94EG8's Avatar
Canadian Civics don't have an ELD.
Old 03-06-2017, 09:04 PM
MisereNoire's Avatar
Small clarification here: Canadian MARKET Civics do not have an ELD. USA Market Civics built in Canada DO.
Old 03-07-2017, 01:23 AM
Seagull Management
94EG8's Avatar
Correct. OP is in Toronto, so chances are he's got a Canadian market Civic.
Old 03-07-2017, 01:42 AM
Fish Twig
tony_2018's Avatar
Gah!!! Didn't see that. Well one less wire to worry about.
Jcgbeasttube
Honda Civic (2006 - 2015)
03-19-2018 10:07 PM
Arch-Angel
02-23-2008 10:25 PM
DaCRXboi
12-19-2006 11:45 AM
YodajdmEK4
10-03-2005 09:24 AM
frost_0ne
09-13-2005 01:02 PM
Quick Reply: Help with EG-Kswap(electrical). ktuned conv harnees.
