header bolts/studs.... one snapped.... replace w/bolts??
Old 08-16-2006, 06:04 AM
miahmouse's Avatar
Default header bolts/studs.... one snapped.... replace w/bolts??
Nearing the end of my recent valve job escapade I go to attach the header. Torqueing down the nuts and bolts I find one of them to be oddly loose... like broken bolt loose...
one of the studs had broken off inside the head... baby jesus began to cry...removed what was left of the stud inside the head and removed the other stud for good measure but I'm left with a dillema. A week long wait for any of the studs or bolts from honda.
the question:
Would using bolts to attach the header work out allright? Do the studs serve any perpose other than aligning the exhaust manifold gasket and easing installation?
Old 08-16-2006, 06:28 AM
TorquelessB16's Avatar
Default Re: header bolts/studs.... one snapped.... replace w/bolts?? (miahmouse)
Which bolt is it?
Old 08-16-2006, 07:05 AM
miahmouse's Avatar
Default Re: header bolts/studs.... one snapped.... replace w/bolts?? (ZeeSix)
It was one of the studs... one of the two on the far corners...#21
Modified by miahmouse at 3:41 PM 8/16/2006
Old 08-16-2006, 07:29 AM
Sleepy_Red_hatch's Avatar
you can run without one for a while.
Old 08-16-2006, 08:11 AM
ironcheftony's Avatar
you can either use bolts or stud's or just run with it missing, u might have a small exhuast leak from it, like mine currently, i believe studs have a stronger seal than bolts or something like that
Old 08-16-2006, 08:22 AM
midnitesol's Avatar
Default Re: (ironcheftony)
i replaced mine with different studs but they snapped again. you'll hav a huge exhaust leak if u dont replace it and u run the possibiltiy of your down pipe breakin off and dragging on the road. it sucks let me tell you! make sure you use new parts!
Old 08-17-2006, 07:04 AM
slowcivic2k's Avatar
Default Re: (midnitesol)
the ITR uses bolt with the exception of two places, the far end on each side, lower studs, to keep the header hanging on the head, and it attaches with bolts, i havent seen an ITR that doesnt do that, so it should be alright.
Old 08-17-2006, 07:27 AM
miahmouse's Avatar
Default Re: (slowcivic2k)
Thanks all... I ended up replacing the studs with bolts...
One thing to note, the studs are a little higher than all the others so it aligns all the others holes dead center when the manifold is hanging there by the studs. If anyone ever does the same thing, put the bolts in where the studs should be first... all the others will go in with ease after that... and have a friend nearby, f-n header is heavy trying to get bolts in while holding and aligning with one hand...
gsrkid24
09-03-2009 05:11 PM
blackcivic11
07-18-2008 12:47 PM
theqballer
13
02-19-2007 01:03 AM
90Integra_Rs
01-12-2007 08:39 PM
Quick Reply: header bolts/studs.... one snapped.... replace w/bolts??
