gsr turbo smoking
Old 12-06-2007, 11:53 AM
crvtt717's Avatar
Default gsr turbo smoking
I have a 93 civic with an obd1 gsr motor from hmotors and just recently my car started smoking a lot out of the exhaust. It ALSO is smoking out of the tube I connected to the valve cover for blow by as soon as I start the car. Could this be my turbo seal, headgasket, pistion rings????? what the expletive? It smokes enough from the tube to where I can see it while I am in the car and the exhaust smokes a lot when I am even at low rpms or as soon as i accelerate. There are no cel's and no odd noises. My car was revving pretty low the day before all the smoke like at 450-500 rpm.
Old 12-06-2007, 11:58 AM
King V's Avatar
Default Re: gsr turbo smoking (crvtt717)
Sounds like you might have bad rings or really bad valve guides. Do a compression/leakdown test and that will tell you the overall health of the engine.
Old 12-06-2007, 12:01 PM
roycivic92's Avatar
Default Re: gsr turbo smoking (King V)
really bad addiction. lol
Old 12-06-2007, 01:05 PM
fmrprojects's Avatar
Default Re: gsr turbo smoking (roycivic92)
is your motor tuned? if not , then there is a chance you could have fried you rings. what color is the smoke? blue is oil and white is coolant.
Old 12-06-2007, 01:06 PM
NOman0608's Avatar
Default Re: gsr turbo smoking (fmrprojects)
like it saids, do a leakdown/comepression test and let us know what you get.
Old 12-17-2007, 07:24 AM
crvtt717's Avatar
Default Re: gsr turbo smoking (NOman0608)
ok i did a compression test and got 75 250 245 135.
my block is shot
Old 12-17-2007, 07:31 AM
JDM_SOHC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crvtt717 &raquo;</TD></TR><TR><TD CLASS="quote">ok i did a compression test and got 75 250 245 135.
my block is shot</TD></TR></TABLE>
R.I.P.
Old 12-17-2007, 08:49 AM
lucky4586's Avatar
Default Re: gsr turbo smoking (JDM_SOHC)
are you sure its the block... I would bet it just the rings.... next time tune you engine
umair
09-24-2010 10:03 AM
umair
09-24-2010 05:16 AM
Rooftop voter
06-14-2007 05:12 PM
luckypon7
09-04-2003 05:36 AM
redteg1
10-09-2002 04:58 AM
Quick Reply: gsr turbo smoking
