Got a check engine light on a 2001 Civic LX!
Old 09-14-2004, 09:36 AM
EG6 SiR's Avatar
Default I need Help from the Honda Gurus!!!!!
A family members car got a check engine light on his 2001 Civic LX and I got the following codes:
P0335(crankshaft position sensor A circuit malfunction)
P0336(crankshaft postion sensor A CKT range/perf)
My question is what needs to be done to correct this? Is it the Crank Position Sensor? Or is the timing off?
I changed the timing belt on this car about five months ago and it just started acting up. It is curently in limp mode and will not let it rev over 3K rpm. If the timing was originally off, then how would it run good for five months? Any help would be greatly appreciated. Thanks!
Old 09-14-2004, 09:42 AM
ej1 pilot's Avatar
Default Re: I need Help from the Honda Gurus!!!!! (EG6 SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Forum Rules &raquo;</TD></TR><TR><TD CLASS="quote">2.A. Please do not post misleading or unspecific thread titles. Please don’t post “Help Needed” or “Look at this problem.” Make your thread titles specific to the question you are asking.
edit- keithv changed title
Modified by Art In Motion at 1:59 PM 9/14/2004
Old 09-14-2004, 09:44 AM
JDMlyfestyle's Avatar
bump for this guy needs a answer.
Old 09-14-2004, 10:09 AM
geckoee's Avatar
I have a 1997 Honda civic and had a TDC sensor check engine light.
Long Story short, I replaced the dissy to fix the problem.
I’m a novice here, so correct me if I wrong, but I was told. The TDC, cylinder 1 and crankshaft position sensor are all in the distributor, and parts are not sold separately. I did a basic tune up first to see if that would do it. Plugs, and timing, cap and rotor, but that didn’t do it, so I replace the distributor. Make sure to unplug the 7.5 amp fuse for 10 seconds to reset the check engine light.
Old 09-14-2004, 10:14 AM
civic-si-2000's Avatar
Default Re: I need Help from the Honda Gurus!!!!! (geckoee)
check all fuses and connections to the crank sensor. It will go into limp mode if no signal is found, or a malfunctionting sensor. the timing belt didnt cause the problem. something is wrong with the sensor. I dont want to throw parts but if you cant find a wiring problem then replace the sensor. i'm betting a bad ground or its become disconnected somehow.
Old 09-14-2004, 10:58 AM
EG6 SiR's Avatar
This is a 2001 civic LX and it has no dizzy. It has individual coils and the Crankshaft position sensor is located right behind the crank pulley. I dont know what to check. All the grounds are good. The connector plugs in tight. The only thing I can think of is the sensor has taken a crap. Thanks for any help.
Old 09-14-2004, 12:25 PM
EG6 SiR's Avatar
Bump for some help!
Old 09-14-2004, 01:19 PM
scratchy's Avatar
did you reset the codes and they came back or what??? i have guys in all of the time with **** like that and i just wipe them out and most of the time i never see them again for that problem, but there has been a couple that have had bad sensors, but grab a timming light and check you timming and your coil packs for misfire
Old 09-14-2004, 10:39 PM
EG6 SiR's Avatar
Default Re: I need Help from the Honda Gurus!!!!! (scratchy)
Yes I did reset the codes and they came back on right away. Also how would the ignition timing affect the CPS if it were misfireing? Thanks!
Old 09-15-2004, 09:47 PM
EG6 SiR's Avatar
ttt
Old 09-16-2004, 11:58 AM
EG6 SiR's Avatar
bump
depoladim
12-11-2012 03:54 PM
Civicta
07-21-2008 06:30 PM
hondagal07
Honda Civic (2001 - 2005)
04-08-2007 06:51 PM
D-rush08
10-12-2006 09:36 AM
nickhans
02-14-2006 01:10 PM
Quick Reply: Got a check engine light on a 2001 Civic LX!
