Gas mileage on 2000 si
Old 08-17-2004, 08:24 PM
Honda97's Avatar
Default Gas mileage on 2000 si
i get 200 miles per full tank. Is that normal?
Old 08-17-2004, 08:27 PM
chronodyne28's Avatar
Default Re: Gas mileage on 2000 si (Honda97)
If you drive harsh all the time then yes it is.
Go here and figure it out.
http://autos.msn.com/research/...sub=0
Honda97's Avatar
Default Re: Gas mileage on 2000 si (chronodyne28)
wat u mean by harsh?
screech's Avatar
depends on how you drive? for a daily driver that sounds horrible because i have a gsr motor in my civic with a 10.9 gallon tank i believe and even driving like a jackass all the time i still manage around 250 miles per tank.
Old 08-17-2004, 08:31 PM
Honda97's Avatar
Default Re: Gas mileage on 2000 si (screech)
if drive slow i get like 230. and if i punch it i get like 170. what can da problem be becasue of. and it cannot be because of the cluster because my car wouldnt start
Old 08-17-2004, 09:19 PM
SiKid86's Avatar
u must have issues because I drive kinda fast and get around 300 a tank :/ on my 99 si
Old 08-17-2004, 10:48 PM
DarkCyde SI's Avatar
Default Re: Gas mileage on 2000 si (SiKid86)
i think something may be wrong with your car because i also get about 300 per full tank
Old 08-17-2004, 11:09 PM
rusted_eyes's Avatar
mine is 250-270 depending on if I drive mostly freeway or in town stop/go. Or if a get on it a lot I get less MPG.
Old 08-18-2004, 05:43 AM
Fastphil's Avatar
On a full tank I can get 400 kms (about 245 miles) at the bare minimum. I've gotten as much as 430 regularly, and even did 500 all highway a couple times.
Old 08-18-2004, 05:46 AM
Senor Miembro
ecahatch's Avatar
ur supposed to get to at least 300 miles per tank...
Old 08-18-2004, 05:49 AM
CRITTERMATT's Avatar
I get 360 regularly. You might need a tuneup.
Old 08-18-2004, 05:53 AM
Sijray21's Avatar
Default Re: Gas mileage on 2000 si (CRITTERMATT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRITTERMATT &raquo;</TD></TR><TR><TD CLASS="quote">I get 360 regularly. You might need a tuneup. </TD></TR></TABLE>
that sounds like a lot to me, how many gallons do u usuall fill up? 10-10.5?
i usually fill up and takes up about 9-10 gallons at about 270-280
I've gotten as low as 210-220, but that's really low, usually Strict City/stop-go driving or higher rpm driving (auto-x, agressive)
Old 08-18-2004, 05:54 AM
jolt-tsp's Avatar
is the diameter of your current wheel/tire setup still stock?
Old 08-18-2004, 09:39 AM
Honda97's Avatar
Default Re: Gas mileage on 2000 si (jolt-tsp)
yeah i didnt touch anything. i jus got new dunlop tires.
Old 08-18-2004, 09:40 AM
GDD4LIFE
phthalo's Avatar
do you have any mods done to your engine or any extra weight?
Old 08-18-2004, 09:42 AM
Sijray21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda97 &raquo;</TD></TR><TR><TD CLASS="quote">yeah i didnt touch anything. i jus got new dunlop tires.</TD></TR></TABLE>
have you run a fuel injector cleaner before? couldn't hurt to try that.
Old 08-18-2004, 09:44 AM
Default Re: Gas mileage on 2000 si (Sijray21)
Yes i fill mine up everytime from empty. I always run it until the low fuel light comes on. Keep in mind I live in WV and drive mostly 2 lane roads. I get pissed when I only get 320 on a tank. My mileage is always between 32 and 34 mpg. It depends on how i drive.
Old 08-18-2004, 09:52 AM
hondainspired's Avatar
All highway miles = around... 350-400 miles to a tank.... i think i figured it for a lil over 40 MPG
City driving with a lil ****** around= is in the 260-270 range... (miles per tank)
Old 08-18-2004, 09:53 AM
Honda97's Avatar
problem solved it is my plugs, and cap. what plugs should i get im thinkin NGK but should i get a stock cap???
93 ex d16z6... prob. no help but... w/e
Old 08-18-2004, 09:55 AM
Honda97's Avatar
Default Re: Gas mileage on 2000 si (hondainspired)
jolt-tsp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda97 &raquo;</TD></TR><TR><TD CLASS="quote">problem solved it is my plugs, and cap. what plugs should i get im thinkin NGK but should i get a stock cap???</TD></TR></TABLE>
NGK or Denso is fine. OEM cap.
How do you know it's the plugs?
Old 08-18-2004, 09:56 AM
Honda97's Avatar
casue there is no other problem i changed my oil 2 days ago, i cleaned my intake filter, i changed my fuel filter, there can be no other problem. and i was actually driving slow i got 200 miles. when i punch it and drive fast i get liek barely 180 its bullshit
Old 08-18-2004, 10:13 AM
Jaydeep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda97 &raquo;</TD></TR><TR><TD CLASS="quote">casue there is no other problem i changed my oil 2 days ago, i cleaned my intake filter, i changed my fuel filter, there can be no other problem. and i was actually driving slow i got 200 miles. when i punch it and drive fast i get liek barely 180 its bullshit</TD></TR></TABLE>
How many miles do you have on them? I think I might need to change in my car too.
Old 08-18-2004, 11:18 AM
jolt-tsp's Avatar
Check compression? Could be a deeper issue thats not too bad yet. I just don't see the plugs causing that dramatic of a milage loss. Hopefully I'm wrong though.
Quick Reply: Gas mileage on 2000 si
