fuel pump wont prime w/ new relay..???
Old 09-24-2007, 08:58 PM
Murk 'EM's Avatar
Default fuel pump wont prime w/ new relay..???
so im almost done with my hatch, fuel delivery is the only thing left... i got the power and ground wired up for the pump itself, when i tried priming it .. nothing happened... u used jumper wires and the pump started priming, so i figured it was the relay... i replaced the relay and still no prime, im not new to this **** ive been working on cars for 7years and im stumped.. the only thing i didnt do is check for voltage (its ****** late and im tired, ive been up sense 5am) so im doing that tomorrow after work but can anyone give me some ideas as to WHAT THE HELL IS WRONG?? that is seriously the only thing holding me back from starting my car... PLEASE HELP!!!
Old 09-24-2007, 09:09 PM
Murk 'EM's Avatar
Default Re: fuel pump wont prime w/ new relay..??? (95_acc0rd)
any help WILL be helpfull
Old 09-24-2007, 09:14 PM
spanishstud's Avatar
i have no idea but GL!
Old 09-24-2007, 09:17 PM
Murk 'EM's Avatar
Default Re: fuel pump wont prime w/ new relay..??? (spanishstud)
again HELP is needed not luck (thanks tho) but lucks not gonna start the car
Old 09-24-2007, 09:20 PM
fatboi07's Avatar
Dude im having the same exact problem. Check to make sure you have the ground secure on the thermostat housing. Im pretty sure that my problem. Goiing to check it out tomm. By the way mine is a 96 civic dx with just a direct replace d16y7 so urs may be different. Hope i could help.
Old 09-24-2007, 09:22 PM
Murk 'EM's Avatar
Default Re: (fatboi07)
yeah i forgot to say.. its a 92 eg hatch with a b16a all grounds are good (motor cranks over with spark) the fule pump primes with the jumper but not the relay new or old?? wtf is wrong here im serioulsy at a loss rig now i have no clue what the problem is
Old 09-24-2007, 10:14 PM
fatboi07's Avatar
talk to syndicate, look under the thred so yeah im seriously pissed and you will see one of his posts on there.
Old 09-25-2007, 06:33 AM
Murk 'EM's Avatar
bump i need help
Old 09-25-2007, 06:43 AM
chuisek9's Avatar
Default Re: (95_acc0rd)
just like i told fatboi07 check the ecu fuse!!if the ecu got o power then it wont send power to the pump!!
Old 09-25-2007, 07:17 AM
Kegan's Avatar
Replace your ECU fuse. Should fix it right up.
Old 09-25-2007, 12:14 PM
Murk 'EM's Avatar
Default Re: (Kegan)
all fuses in tact.. im going to go over all of them with the voltmeter in a little bit
Old 09-25-2007, 01:02 PM
Relic1's Avatar
have you tried a different ECU?
there is a growing common problem with honda ECUs where one of the capacitors in the ECU fails and causes the ECU to never turn on the fuel pump.
not a difficult repair, if you know what you're doing. (pull out the cap, clean up the board, install new cap)
Old 09-25-2007, 01:36 PM
Murk 'EM's Avatar
Default Re: (Relic1)
no i havnt tried a new ecu.. im going to do ignition and ecu checks now
potatostix
10
06-17-2023 10:27 PM
SpoonEk253
41
10-03-2022 03:21 PM
shadysslim
11
04-09-2013 09:52 AM
moaterboaink1ng
10-10-2012 09:07 PM
Elgrys.Mendez
14
08-05-2011 01:26 PM
Quick Reply: fuel pump wont prime w/ new relay..???
