Flare wrench for brake lines...
Hey guys, I'm swapping in rear integra disc brakes tomorrow and would like to just clarify that the only flare wrench to use is a 10mm.
Is that correct? what about the soft lines do I use a normal wrench for those or do I still use the flare wrench?
thanks
thanks
Global Moderator
Re: Flare wrench for brake lines... (Mr.RHTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner »</TD></TR><TR><TD CLASS="quote">Hey guys, I'm swapping in rear integra disc brakes tomorrow and would like to just clarify that the only flare wrench to use is a 10mm.
thanks</TD></TR></TABLE>
I'd use a flare wrench on all of the lines just to make sure you don't strip them..
10mm.
10mm.
Re: Flare wrench for brake lines... (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy »</TD></TR><TR><TD CLASS="quote">
10mm.</TD></TR></TABLE>
lol beat me to it.
lol beat me to it.
Yeah, I learned the hard way on my DA...
Re: Flare wrench for brake lines... (BlueIntegraBoy)
ok but on the MC/BB/prop valve I'm gussing the flare wrench size is 10mm correct? any ideas what the size is for the flex brake lines? Just wanting to know so I can buy the wrenches before I begin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner »</TD></TR><TR><TD CLASS="quote">ok but on the MC/BB/prop valve I'm gussing the flare wrench size is 10mm correct? any ideas what the size is for the flex brake lines? Just wanting to know so I can buy the wrenches before I begin</TD></TR></TABLE>
They should all be 10mm.
Re: (PINEAPPLE)
it is still possible to round off a fitting with a flare nut wrench... it happened to me and it wasn't because I was using the wrong size wrench either
put some penetrating oil on there and make sure all the undercoating is cleaned off of the fittings before you start wrenching on them
good luck
good luck
Re: (IHateJDM)
I'm going to be pulling rear discs off my LS soon.....
If you are interested: http://www.harborfreight.com/c...=5126
Should be good enough since I would not expect the lines to be torqued to 80ft/lbs.
Any tips for removing the brake system?
DOHCgarage919
10-08-2007 04:38 PM
