engine light issue
engine light issue
I have an issue where my engine light is on. I had the diagnostic code of P0108 map sensor high input circuit. I replaced the map sensor but the engine light is still on. What else can I do? I'm open to all any other ideas so i can fix this. Thanks for the help in advance.
Re: engine light issue (g_dogg619)
not sure if you know how to use a multimeter or not but, your probably drawing to much ampereage in to the circuit, or not enough
Imperious: Mod of Valor
Re: engine light issue (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">did you try to reset your ecu? </TD></TR></TABLE>
I would try doing this.
Re: engine light issue (JDM-EJ1)
i have not reset the ecu yet due to having to take the battery cable off and having to get the code from honda for the sterio., but i will try it for sure thank you.
amps and volts are two diff things volts are how much power that is getting .amps are the amount of current flowing into it. if either one is not right. you probably have a problem further in your circuit before the sensor
kaoss_11
09-10-2006 04:14 PM
Ruby Civic
02-01-2004 04:27 PM
