EG6 or EK9 rear camber kit
hello again. can someone explain how these rear camber kit work. I know front camber kit can be adjust +/- for track use better cornering. but these rear camber can be adjustable? Thank you
Re: EG6 or EK9 rear camber kit
How do they work? You loosen the locknuts, rotate the adjustment arm, then tighten the locknuts, adjusting the camber of your wheels. Do you need them for street driving? No. Do you need them for track driving? They wouldn't hurt, but you'd be better off becoming a better driver before you worry about the effects of a degree of camber.
Conciseness is important, then.
To the OP: Yes, front camber can be adjusted for handling, but rear camber, for track use, has just as much effect on handling. You can read more about the effects of front and rear camber here.
I still stand by my statement that before anyone spends money and time fine tuning rear alignment, they should spend more time on the track and on the books becoming a better driver. The best tuned alignment isn't going to suddenly make you Sebastian Vettel.
Navid OG
04-18-2004 11:43 AM
