EG front brakes won't release
Old 05-22-2010, 01:09 PM
WhiteOnRice's Avatar
Default EG front brakes won't release
92 CX
My brakes will not release (non-abs). My fluid was fairly low but there was some left. I've never heard of this happening but I'm assuming that it's the master cylinder because it's both front brakes (rear seem fine though). Anyone know for sure?
If it is the master cylinder I'm assuming that something got into the brake system and destoryed it. How can I clean it out (after replacing MS)?
Thanks.
Old 05-24-2010, 12:16 AM
Default Re: EG front brakes won't release
TTTTTTTT
Old 05-24-2010, 12:36 AM
TheJGB3's Avatar
Were new pads/rotors recently installed? Your brake hoses are probably collapsed. To check them you remove the bolt that holds it to the caliper. Be careful not to lose the brass crush washers (there is one on each side of the hose). If no brake fluid comes out the end of the hose, replace it. Also inspect your caliper piston and the bracket slide pins for proper movement.
94 IntegraLS
21
06-11-2012 08:41 PM
shotime
Suspension & Brakes
11-01-2011 01:33 PM
jdmsir4dr
Suspension & Brakes
03-07-2010 01:23 PM
Mentasti
09-30-2006 03:37 PM
PearlWhiteAccord
10-01-2002 05:47 AM
Quick Reply: EG front brakes won't release
