eBay fog lights on my EK
Old 10-06-2007, 06:41 PM
rarrior23's Avatar
Default eBay fog lights on my EK
Does anyone know if these will fit on my 1997 EK? http://cgi.ebay.com/ebaymotors...wItem
Old 10-06-2007, 06:42 PM
jaydakid86's Avatar
Default Re: eBay fog lights on my EK (rarrior23)
yea they would but i would go with a little bit better quality....maybe save up for some real ones or go passwordjdm.com
Old 10-06-2007, 06:46 PM
rarrior23's Avatar
I couldn't find any on passwordjdm.com, unless I'm just stupid.
Old 10-06-2007, 06:50 PM
dangthemang's Avatar
i guess you're stupid. haha jk.
http://passwordjdm.com/Passwor....aspx
Old 10-07-2007, 10:11 AM
99fbpem1's Avatar
Default Re: eBay fog lights on my EK (dangthemang)
I have heard bad things about password lately. I bought mine from a sponsor on here (probably the same ones on ebay and password) Everything looked quality except the switch was complete garbage. I'm getting an OEM one so it doesn't matter that much to me.
Old 10-07-2007, 10:43 AM
CarbonizedDX's Avatar
Default Re: eBay fog lights on my EK (99fbpem1)
password units are Depo's just like Ebay. I've had depos on my 96 for over a year with ZERO issues....
Old 10-07-2007, 11:05 AM
ke98248's Avatar
Default Re: eBay fog lights on my EK (jaydakid86)
Those look like Depo Fogs to me, not the highest quality lol
Old 10-07-2007, 11:38 AM
Redbone's Avatar
i tried the EBAY ones and the wiring was completely wrong. Just get real ones.
Old 10-07-2007, 12:56 PM
pdiggitydogg's Avatar
Default Re: (Redbone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redbone &raquo;</TD></TR><TR><TD CLASS="quote">i tried the EBAY ones and the wiring was completely wrong. Just get real ones.</TD></TR></TABLE>
Id like to see you find oem yellow fogs. I only ever talked to one person who had them, and was shocked by it.
My fogs are Esuse - theyre alright. I had a sealing issue once, fixed it, nothing since.
If I were to buy a new set, Id throw on a bead of clear silicone straight away and Im sure Id have no problems at all.
Regarding the wiring...find the problem and fix it. So what if something isnt pinned correctly? Thats a 30 second fix.
Anyways.... To the OP: Yes, those ebay fogs will fit your 97...
Old 10-07-2007, 01:04 PM
ke98248's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">
Did yours leak moisture in?
Anyways.... To the OP: Yes, those ebay fogs will fit your 97...</TD></TR></TABLE>
Old 10-07-2007, 01:05 PM
Default Re: (ke98248)
Yes, condensation formed inside because the outer glass was not well sealed to the rest of the housing.
Old 10-07-2007, 01:11 PM
ke98248's Avatar
yeah that's the problem i'm having again with my depo yellow square fog lights.. i got a replacement one (the other was fine).. Did you just take it apart, dry it out and then seal it up with silicone? What'd you seal up exactly?
Old 10-07-2007, 07:49 PM
Redbone's Avatar
it wasn't a question of repinning anything. All the connectors were wrong for my application. But I didn't see that they were yellow cause i was at work. Clear work far better if you really want to see from experience.
Old 10-07-2007, 08:24 PM
H-T White Ops
NOFX's Avatar
Default Re: eBay fog lights on my EK (CarbonizedDX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CarbonizedDX &raquo;</TD></TR><TR><TD CLASS="quote">password units are Depo's just like Ebay.</TD></TR></TABLE>
Yep.
I've had DEPOs previously on my '98 Civic. They were HORRIBLE! I had wiring issues where the ground wouldn't connect properly and so one light would turn on and off randomly. Then there was the water leak I couldn't stop. I don't mean condensation would build up. I mean water would collect incredibly fast and quickly amount to an inch or so of water in there. I even blew a bulb once because it went under water. It exploded in the housing. I tried to fix it by putting a thin coat of silicone carefully around the edge of the housing. It still leaked just as bad. I put tons of silicone all around the outer edge AND IT STILL LEAKED. I tried spot sealing anything I thought might be the source. Nothing solved it.
Eventually I got a new set when Eran and I were trying to fix the grounding issue and the screw that holds the bulb clip on snapped off in the housing.
If you have to have aftermarket, Esuse &gt; DEPO.
Oh, and Esuse lights also plug into the stock exterior foglight harness. DEPO lights have a long gaudy red wire...
Old 10-07-2007, 08:31 PM
Default Re: eBay fog lights on my EK (NOFX)
huh guess I got the rare batch of depo's, I've not had any issues with wiring or lighting. Yes they've got the red wire but with the full loom and a little strategic wiring it's all but unnoticeable...
You can buy the OE units from the dealerships, but if you want amber units you can either get the lamin-x film to tint them yellow, spray the lenses yellow with stain glass paint or get a amber depo kit and then use the honda OE wiring to power them...
And here is the hurt:
#23339 FOGLIGHT KIT list 259.00 our price 173.53
as found HERE
Old 10-07-2007, 08:45 PM
H-T White Ops
NOFX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CarbonizedDX &raquo;</TD></TR><TR><TD CLASS="quote">huh guess I got the rare batch of depo's, I've not had any issues with wiring or lighting. Yes they've got the red wire but with the full loom and a little strategic wiring it's all but unnoticeable...
as found HERE</TD></TR></TABLE>
The OEM USDM foglights are round and clear. No other variation for the USDM ones.
And that's a great price for true OEM parts that you know won't be shitty.
Modified by NOFX at 12:46 PM 10/8/2007
Old 10-08-2007, 11:36 AM
RioSmAn's Avatar
yea ebay same quaily just make sure you read the discription and stuff like that just got 00 fog lights for my coupe fits great works great.
Old 10-08-2007, 07:15 PM
the slow and the serious's Avatar
Default Re: (RioSmAn)
i had ebay fogs..worked out just fine for me..till i lost it to sum bonehead cutting me off
Old 10-09-2007, 04:59 AM
lponcian5799's Avatar
i ordered mines from passwordjdm.com and i got depo's. not the greatest quality. a wire had already come loose off of it causing me hours and hours of smashing my head against my car.
dj_justice
Lighting
08-25-2013 06:22 PM
fastrxu
Suspension & Brakes
15
10-18-2009 09:26 PM
racehard81
Honda Civic (2006 - 2015)
02-05-2008 04:57 PM
shadohconspiracy
16
09-14-2007 11:25 AM
turnsignalandy
11-25-2006 11:47 PM
Quick Reply: eBay fog lights on my EK
