dual core / half size radiator questions for turbo
Old 10-02-2006, 07:26 PM
dafuzzbudd's Avatar
Default dual core / half size radiator questions for turbo
i understand what a dual core radiator is.
since it is thicker would that get in the way of a radiator compliant turbo manifold?
half size radiators allow fitment of the intercool right?
looking straight at the car, is it half size by tallness or wideness?
im trying to picture the whole fitment in my head but the triangle wont go into the square hole
Old 10-02-2006, 07:27 PM
Patron's Avatar
Default Re: dual core / half size radiator questions for turbo (dafuzzbudd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dafuzzbudd &raquo;</TD></TR><TR><TD CLASS="quote">i understand what a dual core radiator is.
im trying to picture the whole fitment in my head but the triangle wont go into the square hole</TD></TR></TABLE>
Dual core radiator is just that, two cores. If you have a 92 civic, it's "half" the length. It's "twice" the width. Same height.
Old 10-02-2006, 07:32 PM
dafuzzbudd's Avatar
Default Re: dual core / half size radiator questions for turbo (ptran13)
hm.. so if it's half the length that allows for any type of manifold...
isn't the intercooler still blocking part of the radiator?
Old 10-02-2006, 07:34 PM
Patron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dafuzzbudd &raquo;</TD></TR><TR><TD CLASS="quote">hm.. so if it's half the length that allows for any type of manifold...
isn't the intercooler still blocking part of the radiator?</TD></TR></TABLE>
Depends on where you mount the IC, what the size of the intercooler is. I know my IC blocked part of my radiator.
Old 10-02-2006, 07:37 PM
dafuzzbudd's Avatar
so for a smaller project a shorter intercooler that doesnt block the radiator so much would be all good?
Old 10-02-2006, 07:42 PM
Patron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dafuzzbudd &raquo;</TD></TR><TR><TD CLASS="quote">so for a smaller project a shorter intercooler that doesnt block the radiator so much would be all good?</TD></TR></TABLE>
Picture for reference, it took quite a bit of space, but still could flow air to the radiator. I'll get a closer pic, this is the only one I have hosted right now.
Old 10-02-2006, 07:44 PM
dafuzzbudd's Avatar
very nice, clean/simplistic look
Old 10-02-2006, 09:55 PM
dafuzzbudd's Avatar
will a dual-core non-1/2 rad. work with a manifold like this
or liek this
Old 10-02-2006, 10:21 PM
Farmer Brown's Avatar
The AC is what usually gets in the way. You should be ok.
Old 10-02-2006, 10:32 PM
dafuzzbudd's Avatar
right now im buying a regular size dualcore, i dont want that to get in the way if a turbo later.
what factors if the ac gets in the way?
Old 10-02-2006, 10:38 PM
turbociviccoupe's Avatar
Default Re: (dafuzzbudd)
people go halfsize because the turbo gets in the way not the a/c...just more room for your manifold and your radiator isnt next to the burning hot manifold+turbo
Old 10-03-2006, 04:53 AM
dafuzzbudd's Avatar
Default Re: (turbociviccoupe)
so the ac wont be hittin against the turbo/mani?
Old 10-03-2006, 09:41 PM
VtecnTurbo's Avatar
they have turbo manifolds that allow you to keep a/c & those that dont. the dual core rad will be fine with no problems, the most you may have to do is shave off some of the black plastic from your stock cooling fan , depending on which side you put your turbo. air flows through your intercooler cooler right to your radiator.
running front mount and stock dual core radiator on 13psi no heating issues.
these always water wetter & other coolant additives if your worried about heat
LsOnBoost
02-02-2007 03:36 PM
puredragcrx
07-02-2006 12:37 PM
Speedraca01
02-19-2006 09:05 PM
4wsB21a
07-11-2002 08:36 PM
Quick Reply: dual core / half size radiator questions for turbo
