Drop 6-speed tranny into 94 del sol???
Old 08-27-2011, 01:42 PM
94_DEL_SOL_VTEC's Avatar
Default Drop 6-speed tranny into 94 del sol???
i was wondering if anyone has done, seem or knows if its possible to drop a 6-speed tranny in a 94 delsol?
D16Z6 1.6L Vtec
just to give a little extra kick and to save even more gas on my long road trips
thanks
Old 08-27-2011, 07:15 PM
Seagull Management
94EG8's Avatar
Default Re: tranny swap question? delsol 94???
Not possible unless you want to swap in a K-series engine along with it, you're looking at large amounts of money.
Old 08-28-2011, 04:58 PM
Weizhang115's Avatar
Default Re: Drop 6-speed tranny into 94 del sol???
It could be done B and D series I call ppg gear they say it could be done with custom mounts and hybrid racing shifter box they tell me is going to be min of 10k maybe more so to answer you question yes it can be done but why a k20/k24 swap is around 6-7 k make more power stock then a fully build b series
Old 08-28-2011, 05:24 PM
virgineg6's Avatar
How would a 6 speed give you more kick on a single cam? Your better of getting an ex tranny and getting a vx/cx 5th gear installed.
Old 08-28-2011, 06:25 PM
apexi_rsx's Avatar
you would be better off just changing the final drive to a 4:77 like the 6 speed but in your 5speed trans. no d or b series made 6 speeds so the tranny being from a k series would make this a very hard swap to do without spending lots of money.
Old 08-28-2011, 06:41 PM
Seagull Management
94EG8's Avatar
You need more than that unless you want 6 reverse gears, K-series turns clockwise, D-series turns counter clockwise.
5th is the same either way .702 for all D-series trannys, except '92 - '95 Si trannys (from hatchbacks and Del Sols only) at .750
Old 08-28-2011, 09:36 PM
Wrona's Avatar
what tranny did the wagovan come with the AWD 6 Speed
Old 08-29-2011, 03:57 AM
dreadhead89's Avatar
The wagovan tranny basically has two first gears, one just low for getting threw/getting unstuck. Plus that tranny runs a diff so you could only use it if u doin the whole rt4w.
Old 02-15-2014, 11:48 AM
Hysterically Calm
TomCat39's Avatar
Dredging this up from the dead....
No one asked... Can this tranny be regeared? Make it so it doesn't have two first gears instead make it have 1-6? Full custom rebuild sounds cheaper than any other option I've read about, granted you'd also be doing AWD.... Still think this could be kewl if you had the money.
Be some weird shifting, think you'd make the "low" first be 6th but might be doable...
94delsolcivic
13
03-13-2016 01:43 PM
Sol Purpose
02-10-2012 02:43 PM
snox425
Transmission & Drivetrain
03-26-2010 09:29 PM
massive_mark
09-11-2008 09:21 AM
wagdad
12-28-2004 01:30 PM
Quick Reply: Drop 6-speed tranny into 94 del sol???
