DOT 3 or DOT 4 for clutch fliuid
Old 11-20-2009, 11:17 PM
new_climber's Avatar
Default DOT 3 or DOT 4 for clutch fliuid
I want to purge my clutch fluid being it is looking pretty dirty. I have read that it takes DOT 3 brake fluid. I was at Napa and they had Valvoline DOT3/DOT4 sync....is that OK to use for both brake and clutch fluid...
It is a 93 civic EX
Old 11-20-2009, 11:45 PM
Linked's Avatar
Default Re: DOT 3 or DOT 4 for clutch fliuid
ive heard that dot 4 means it can take a higher temperature.
if its ok to mix dot 3 and 4 for brakes indicating dot 3
it may be ok for clutches
Old 11-20-2009, 11:50 PM
Koopa Troopa's Avatar
The increased dry boiling point of DOT 4 really doesn't warrant the added cost. With a clutch line, just use DOT 3.
Old 11-21-2009, 04:31 AM
The_Honda_Guy's Avatar
It doesn't matter really, DOT 4 can be used in place of DOT 3. They're generally the same price too. Also, DOT 4 will be less prone to absorbing moisture and is less hygroscopic. DOT 3 is thirsty stuff.
Old 11-21-2009, 04:36 AM
batallic's Avatar
since yur car uses dot 3 you can use dot 4,
Old 11-21-2009, 06:25 AM
Ferio4ya's Avatar
dot 3 is most recommended. brakes and clutch.
maxogsr
03-29-2010 06:43 AM
NoLipRacen
12-23-2003 11:24 AM
IntEGNYC
11-06-2003 11:22 PM
ragejed
09-12-2002 10:59 PM
magic hat #9
08-23-2002 09:21 AM
Quick Reply: DOT 3 or DOT 4 for clutch fliuid
