DOHC ZC with a Z6 Trans
Old 12-20-2006, 02:32 AM
Gold DA9's Avatar
Default DOHC ZC with a Z6 Trans
My friend has OBD-0 ZC sitting in his garage from his now B16 CRX. I recently blew my Z6 and I was wondering what was all needed to do with this swap. I have read about removing the halfshaft and what not from the ZC.
Im just trying to get my Del Sol running. Also does anyone know where I can find a OBD-1 ZC dizzy? Also how different are the two exhaust manifolds???
edit:
Also what parts would I be able to change over from my Z6 to the DOHC ZC? Is it possible to convert the ZC dizzy to OBD1?
Modified by Gold DA9 at 7:08 AM 12/20/2006
Old 12-20-2006, 06:00 AM
Cvic90's Avatar
Default Re: DOHC ZC with a Z6 Trans (Gold DA9)
you can't make the OBD-O dizzies OBD-1. There have been some gen2 OBD-1 DOHC ZC dizzies on ebay.
Old 12-20-2006, 07:01 AM
Gold DA9's Avatar
Default Re: DOHC ZC with a Z6 Trans (Cvic90)
Is it possible to use any other obd-1 dizzy on the motor?
Old 12-20-2006, 08:18 AM
I_dont_want_a_user_name's Avatar
I belive you can use the old obd0 dizzy if you get it repined to fit your harness
Old 12-20-2006, 08:38 AM
dem0nk1d's Avatar
just start bolting up obd1 and up distributors and find which one will workj the best. You might only get one or two bolts to match up. Then i guess you could make an adapter plate out of sheet metal.
Old 12-20-2006, 03:41 PM
Go Tigers!
Bense's Avatar
trans will bolt up to the engine fine, remove the zc halfshaft and use your stock z6 axles.
worst comes to worse and you have a 1988 zc. If that's the case, use your z6 clutch/flywheel/pressure plate
low91rex
12
08-06-2007 10:27 AM
clsmooth
11-18-2003 11:24 AM
jdm169
05-28-2003 09:13 PM
Quick Reply: DOHC ZC with a Z6 Trans
