Does N e one No where is the main relay on the 92 Hatchback civics.
Old 09-17-2003, 07:55 PM
Phaze1_Ls's Avatar
Default Does N e one No where is the main relay on the 92 Hatchback civics.
Any one noes wheres the main relay on the hatchbacks.
Old 09-17-2003, 08:01 PM
B19CivicHB's Avatar
Default Re: Does N e one No where is the main relay on the 92 Hatchback civics. (Phaze1_Ls)
If you are sitting in the driver's seat, it is directly above the dead-pedel. It is a small grey box mounted by a bracket with one bolt. Has like a 20 pin connector in it.
HTH,
-Nick-
Old 09-17-2003, 09:23 PM
I to Smooch Pickle
mingchi69's Avatar
is your car dying on you?? if so.. instead of spending $50 on a new main relay, u might just want to resolder the connection on your existing one. works the same.. and saves u money
Old 09-24-2003, 03:18 PM
J2turbo21's Avatar
Default Re: Does N e one No where is the main relay on the 92 Hatchback civics. (mingchi69)
My car died on me while i was driving and now it doesnt want to start.I started it again on saturday for a minute and shut it off just to see if it would start.Monday i installed some dsm injectors and resistor box and then it didnt want to start.The car is getting spark,fuel pump is priming and there is pressure in my fuel rail.Just wondering if this could cause this to happen.
Old 09-24-2003, 03:28 PM
RedlinedVTEC's Avatar
Well if you need a main relay I have a spare I can hook you up with for a good price cause it's just sitting in my tool box.
Old 09-25-2003, 10:30 PM
J2turbo21's Avatar
Default Re: Does N e one No where is the main relay on the 92 Hatchback civics. (RedlinedVTEC)
Ok let me see if thats the problem and if it is i'll hit you up.
Old 09-25-2003, 10:36 PM
TheAutoboxer
Guest
Posts: n/a
Default Re: Does N e one No where is the main relay on the 92 Hatchback civics. (J2turbo21)
welll ?
Old 09-25-2003, 10:38 PM
J2turbo21's Avatar
Default Re: Does N e one No where is the main relay on the 92 Hatchback civics. (menkio)
Well its night time and raining so i havent had a chance to check it.Also what am I looking for to see if its broken?
Old 10-02-2003, 03:42 PM
J2turbo21's Avatar
I found out my injectors arent getting power.I used a tester and a volt meter and its not showing any signs of power.Anyone know how to open up the relay and what am i looking for if its broke?
Old 10-02-2003, 03:47 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J2turbo21 &raquo;</TD></TR><TR><TD CLASS="quote">My car died on me while i was driving and now it doesnt want to start.I started it again on saturday for a minute and shut it off just to see if it would start.Monday i installed some dsm injectors and resistor box and then it didnt want to start.The car is getting spark,fuel pump is priming and there is pressure in my fuel rail.Just wondering if this could cause this to happen.</TD></TR></TABLE>
If the car is getting spark, and the fuel pump is priming, then the Main Relay is GOOD.
The CEL comes on and goes off after two seconds with the key in the ON position correct?
Sounds like you possibly wired up the injectors incorrectly or the resistor box is bad.
How exactly did you wire up the resistor box?
Old 10-02-2003, 03:48 PM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J2turbo21 &raquo;</TD></TR><TR><TD CLASS="quote">I found out my injectors arent getting power.I used a tester and a volt meter and its not showing any signs of power.Anyone know how to open up the relay and what am i looking for if its broke?</TD></TR></TABLE>
The main relay is fine!
Sounds like you hooked up the resistor box wrong.
What colors are on the resistor box? 4 black and 1 red?
D7KWagon
08-05-2014 01:57 PM
Hondaciv866
08-19-2012 02:01 AM
rasinhell
03-07-2005 06:09 AM
Elisa
06-17-2004 01:30 PM
Quick Reply: Does N e one No where is the main relay on the 92 Hatchback civics.
