Distance between brake pad and rotor
Old 11-20-2009, 03:47 PM
xkwzt21's Avatar
Default Distance between brake pad and rotor
Can anyone tell me how much space there is supposed to be between the brake pad and rotor on a 1996 Civic LX? Looking at it with the naked eye it appears that the pad is riding the rotor and there is no space, which leaves me to believe that the caliper or piston is frozen and the pad will wear out prematurely. This is the same for both of the front brakes. This is also the same for all 4 brakes on my brothers acura. Not sure if this is something that I need to worry about or not. Any insight would be great.
Old 11-20-2009, 03:57 PM
Koopa Troopa's Avatar
Default Re: Distance between brake pad and rotor
There should be no space between visibly. If there were it'd take seconds for your pads to touch the rotors, most likely making you crash.
Tenzo
Suspension & Brakes
05-13-2012 11:03 AM
tjluvsahonda
10-04-2007 08:09 AM
Fatcobra
03-27-2007 11:45 AM
n8byte
03-20-2007 07:18 PM
realis9
02-16-2006 05:41 PM
Quick Reply: Distance between brake pad and rotor
