Del Sol Shift Linkage Help
Old 08-02-2008, 12:02 AM
monsterb18b's Avatar
Default Del Sol Shift Linkage Help
I have a 94 integra LS shell and I have this del sol non-vtec motor laying around.
The integra shift linkage is too long and so is the del sol shift linkage.
Can anyone tell me what shift linkage will fit this swap?
I was thinking b-series del sol linkage?
Old 08-02-2008, 12:42 AM
BlueIntegraBoy's Avatar
Default Re: Del Sol Shift Linkage Help (monsterb18b)
You need a 92-00 Civic d-series linkage.
Old 08-02-2008, 10:04 AM
Default Re: Del Sol Shift Linkage Help (BlueIntegraBoy)
Thanks. For the help. Have people done this swap before. I'm finding it rare.
Old 08-02-2008, 10:08 AM
Seagull Management
94EG8's Avatar
Its rare because its almost unheard of to drop a smaller engine than stock in a honda. That being said it shouldn't be hard. If a B-series engine and transmission will drop right in a civic that originally had a D-series then it only stands to reason that a d-series should drop right in an integra that originally had a b-series. It will be pretty gutless though.
Old 08-03-2008, 09:39 PM
Default Re: Del Sol Shift Linkage Help (94EG8)
Thanks for the help.
Old 08-11-2008, 01:32 AM
jakeypoo12's Avatar
the del sol shift linkage is longer than the linkage from another civic with a d series trans?
Old 08-11-2008, 02:11 AM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 &raquo;</TD></TR><TR><TD CLASS="quote">Its rare because its almost unheard of to drop a smaller engine than stock in a honda. That being said it shouldn't be hard. If a B-series engine and transmission will drop right in a civic that originally had a D-series then it only stands to reason that a d-series should drop right in an integra that originally had a b-series. It will be pretty gutless though.</TD></TR></TABLE>
Yeah, the LS is a torquey lil bitch (more torque than a B16 and almost as much as a GSR). It's a nice power plant for the LS since they're a bit on the heavy side. Putting a torqueless stock D series motor in there is kinda crazy. It'll be A LOT slower than stock, and ur fuel mileage won't be as good. It's a swap that's done out of necessity, not by choice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jakeypoo12 &raquo;</TD></TR><TR><TD CLASS="quote">the del sol shift linkage is longer than the linkage from another civic with a d series trans?</TD></TR></TABLE>
It doesn't matter.
The OP is taking a D series engine/trans that was in a del sol and putting it into an Integra. That same engine/trans (SOHC non-VTEC (D15B7)) was offered in the civic LX/DX. He doesn't need to mess with del sol anything because it wouldn't be any different if he had just pulled that motor out of a DX or LX. Civic D series linkages will plug into that. The del sols were a bit different in length, I do believe, but the del sol has little play into the OP's swap.
Old 08-11-2008, 06:11 AM
Little_Nolan's Avatar
Default Re: Del Sol Shift Linkage Help (Syndacate)
Go for the Dswap, it will be bad azz
redline870
03-23-2011 09:30 AM
imnotted
05-25-2008 12:17 PM
turbodelsol3
03-09-2007 11:57 PM
vtec25
12
12-02-2006 05:21 PM
jaydmej1
05-20-2004 08:30 AM
Quick Reply: Del Sol Shift Linkage Help
