Del sol - headunit cuts off then turns right back on and headlights dim
Old 12-01-2011, 04:49 AM
z0mby's Avatar
Default Del sol - headunit cuts off then turns right back on and headlights dim
93 del sol, d16y7, 5 speed all original. Lately, ill be driving, and my headunit will cut off then turn right back. Ill be driving, and for no reason, it just cuts off and immediately comes back on. Ive had the alternator, starter, and battery all tested and it passed. I then checked the alternator belt and it was "slightly" loose. So I tightened it a bit drove on it and had no issues. However, when I came home last night I let the car idle in my driveway with everything on(running lights, headlights, etc.). After a few minutes of idle the headlights dim, and the car dropped idle but goes back to normal. Im kinda stumped here. Early warning sign of the alternator going bad?
Old 12-01-2011, 05:00 AM
Former User's Avatar
Default Re: Del sol - headunit cuts off then turns right back on and headlights dim
What are the voltages across the two battery posts with the warm engine idling under no electrical load versus high electrical load (high beams, A/C max, rear window defogger)?
Old 12-01-2011, 06:32 AM
Daeity's Avatar
yeah or you have a wire that is causing you to short out. Ex-gf has an issue like this but the car would just shutoff after 5 mins of idle/drive, It was a loose wire...:S
Old 12-01-2011, 06:56 AM
z0mby's Avatar
I will check and let you know. Theres no issue when its during the day. Before I tightened the belt id shift from 1st to 2nd and as im accelerating I could feel the car losing power
. Now, it hasnt done it lately. At night even when I had the headunit off, I was letting the car idle with the headlights on and youd see them dim then come right back.
Old 12-02-2011, 09:20 PM
z0mby's Avatar
Going to use the volt meter tomorrow. What should the voltages read on the battery while the car is under no load vrs a load?
Old 12-03-2011, 09:48 AM
z0mby's Avatar
14 under no load. 13 under a load. High beams, blower motor, etc.
Old 12-03-2011, 01:30 PM
Give decimal values. 14 point what? 13 point what?
Old 12-03-2011, 08:01 PM
z0mby's Avatar
Why would that matter? It stayed a solid 13 and 14. Between 12 to 15
so that says its not the batt.
Old 12-03-2011, 08:48 PM
The decimal values are important. For example, if your reading was 13.0V under load, then the alternator is shot. If on the other hand your reading was 13.8V under load, then the alternator is fine.
Old 12-04-2011, 04:11 AM
z0mby's Avatar
Ok. Makes sense. Ill check again. Keep in mind that it doesnt do this all the time. Just occasionally.
Old 12-05-2011, 05:38 AM
z0mby's Avatar
14.1 no load under a heavy load 13.1-13.5
Old 12-05-2011, 05:44 AM
z0mby's Avatar
12.8. Slowly decreasing.
Old 12-05-2011, 06:26 AM
13.1V in this test is too low. Suggests alternator problem.
Heavy load?
Old 12-05-2011, 07:12 AM
z0mby's Avatar
Heavy load?
Yes, under no load it stayed a consistant 14.1. Under a heavy load(blower motor all the way on, headlights/high beams, radio, etc.) it started at 13.6 then slowly decreased 13.4, 13.2, 13.1, etc. Then made it all the way down to 12.6. I'm replacing the alternator right now...
Old 12-05-2011, 07:13 AM
Texas4door's Avatar
Easier alternator test:
Unhook your battery cables while the car is running
If it dies or dims pretty quick, it's definitely the alternator on the way out
If there's no difference in lights dimming, might be a wire loose somewhere
Old 12-05-2011, 08:36 AM
z0mby's Avatar
I totally forgot to do that. I put the alternator on and it seems to be doing ok. I will keep you up to date if anything persists. I really appreciate the help, Ron. Thanks.
Old 12-05-2011, 08:46 AM
krazyrider112's Avatar
Yea sounds like an issue with the alternator which is causing you to loose power...Should look into a new one...GOOD Luck
Old 12-05-2011, 09:23 AM
Never do this test. It risks damaging sensitive electrical components.
gokus-eg2
01-26-2012 12:09 PM
F120man
15
12-22-2003 06:57 AM
Behan
07-17-2003 03:33 PM
AGPSuperstar
02-07-2003 10:17 AM
gsrstyle
11-16-2002 03:47 AM
Quick Reply: Del sol - headunit cuts off then turns right back on and headlights dim
