Del sol - headunit cuts off then turns right back on and headlights dim
93 del sol, d16y7, 5 speed all original. Lately, ill be driving, and my headunit will cut off then turn right back. Ill be driving, and for no reason, it just cuts off and immediately comes back on. Ive had the alternator, starter, and battery all tested and it passed. I then checked the alternator belt and it was "slightly" loose. So I tightened it a bit drove on it and had no issues. However, when I came home last night I let the car idle in my driveway with everything on(running lights, headlights, etc.). After a few minutes of idle the headlights dim, and the car dropped idle but goes back to normal. Im kinda stumped here. Early warning sign of the alternator going bad?
Re: Del sol - headunit cuts off then turns right back on and headlights dim
What are the voltages across the two battery posts with the warm engine idling under no electrical load versus high electrical load (high beams, A/C max, rear window defogger)?
yeah or you have a wire that is causing you to short out. Ex-gf has an issue like this but the car would just shutoff after 5 mins of idle/drive, It was a loose wire...:S
Originally Posted by RonJ@HT
(Post 46444696)
. Now, it hasnt done it lately. At night even when I had the headunit off, I was letting the car idle with the headlights on and youd see them dim then come right back. |
Going to use the volt meter tomorrow. What should the voltages read on the battery while the car is under no load vrs a load?
14 under no load. 13 under a load. High beams, blower motor, etc.
Give decimal values. 14 point what? 13 point what?
(Post 46457760)
so that says its not the batt. |
The decimal values are important. For example, if your reading was 13.0V under load, then the alternator is shot. If on the other hand your reading was 13.8V under load, then the alternator is fine.
(Post 46459460)
Ok. Makes sense. Ill check again. Keep in mind that it doesnt do this all the time. Just occasionally. |
14.1 no load under a heavy load 13.1-13.5
12.8. Slowly decreasing.
Originally Posted by z0mby
(Post 46465233)
(Post 46465255)
(Post 46465414)
13.1V in this test is too low. Suggests alternator problem.
Heavy load? |
Easier alternator test:
Unhook your battery cables while the car is running If it dies or dims pretty quick, it's definitely the alternator on the way out If there's no difference in lights dimming, might be a wire loose somewhere ^^; |
Originally Posted by Texas4door
(Post 46465649)
Yea sounds like an issue with the alternator which is causing you to loose power...Should look into a new one...GOOD Luck
(Post 46465649)
Unhook your battery cables while the car is running |
