d16z6 tranny on a d16y7 motor?
Old 09-07-2010, 07:23 AM
Xxcivic97xX's Avatar
Default d16z6 tranny on a d16y7 motor?
I have a 97 civic coupe 5-speed and was wondering if i could put the d16z6 si tranny on my d16y7 motor cause i need a new transmission and was wondering which would be the safer route to go. or should i just stick with the reg. tranny? what differences would it make?
Old 09-07-2010, 07:24 AM
kaiba's Avatar
Default Re: d16z6 tranny on a d16y7 motor?
Will fit.
Old 09-07-2010, 07:28 AM
D Griff's Avatar
The Z6 will work fine. I would go with it because the gears are shorter.
Old 09-07-2010, 01:55 PM
would i have to do any more (upgrades) or install anything else to make it work or just take the old one off and put the new on. and would the d16z6 si tranny be better tranny than a d16y8 one, which im guessing so but just wondering.
Old 09-07-2010, 02:01 PM
Seagull Management
94EG8's Avatar
Nothing else needs to be done. Simply remove the Y7 tranny and install the Z6 tranny.
Z6 and Y8 trannys are pretty similar, they have almost identical gearing and mount exactly the same, the only real difference is the Z6 uses aluminum shift forks, the Y7/Y8s use steel forks.
Old 09-07-2010, 08:03 PM
alright thankyou everyone. now to find a really great one for cheap near me.
Old 11-03-2010, 03:34 PM
SteetJustice's Avatar
dont wana jack threads but what iff the d16y7 is hydrolic clutch and the si tranny is a cable clutch, would you need a different clutch?
Old 11-03-2010, 04:54 PM
Seagull Management
94EG8's Avatar
Depends on what year the Si tranny is out of. If its an '88 then yes, if its an '89 - '91 you can use a hydro clutch (in either case you'll need a cable throwout bearing though) Note that if this transmission is going into a '92 - '00 Civic, stop, its just absolutely not worth it. D-series hydro trannys are dirt cheap, for what mounts and a hydro to cable conversion cost you'll be way further ahead buying a hydro tranny. If its going into an '88 - '91 Civic then carry on.
Old 11-03-2010, 05:55 PM
EkLanta's Avatar
I'm swapping out my S40 from my y7 also. And I'm replacing it with a S20. I think its a z6. And i was told the same thing too, just take off the old transmission and put in the newer(used) transmission.
Old 11-03-2010, 06:06 PM
Seagull Management
94EG8's Avatar
Same deal, remove old tranny, install new tranny, fill with fluid. Done.
Old 02-16-2017, 11:10 PM
Majestic 707's Avatar
Hi guys I some to hit me with some Honda notledge. I have 96 DX with a d16y7 now. Is the d16z6 engine & transmission mounts are the same fit. To do the swap also, axels needs to be changed too with the ECU? Can someone help please... Thanks
Old 02-17-2017, 05:40 PM
crazyhorse2011's Avatar
Oh lawdy..... where to begin with this....
Raocorp
15
05-20-2009 09:14 AM
SEATownboi08
02-20-2008 07:09 PM
bowdown201
09-18-2007 10:32 AM
Burke
05-10-2004 07:37 AM
fsck3r
10
12-23-2002 03:58 PM
Quick Reply: d16z6 tranny on a d16y7 motor?
