*Urgent* 99 civic sputtering, check engine light flashing!
Old 04-25-2009, 10:40 PM
big_poppa492004's Avatar
Default *Urgent* 99 civic sputtering, check engine light flashing!
I neep help with my 99 civic 4dr sedan. It has a SOHC D16 motor in it. Today it started sputtering upon acceleration. It will run at idle and not cut off, but it even sputters then. The check engine light flashes, then goes back and stays on, then back to flashing. Sputtering is pretty constant. Almost sounds like its running on 3 cylinders. Sputtering dont do it as bad at higher RPM's, but you can tell its still there.
Here is what I have tried so far, didn't help at all:
Each plug wire is getting fire and connect good
Dist. cap inside is dry and free of dirt/rust/debris, even scraped metal 'pins' on cap
Installed brand new spark plugs
does have gas, lol
Any ideas??? Thanks in advance!!!
Old 04-25-2009, 11:12 PM
New User
frog276's Avatar
Default Re: *Urgent* 99 civic sputtering, check engine light flashing!
i had the exact same problem with my 2000 civic coupe. it started when i ran out of gas. i replaced the plugwires and it ran smooth after that.
Old 04-25-2009, 11:13 PM
SOHC_4dr's Avatar
GET YOUR LIGHT CHECKED!!! that should be the #1 thing to do and it will tell you what is ****ed up. it seems like a miss though. check the light then come back if you need to
Old 04-25-2009, 11:14 PM
keeler's Avatar
I would check wires like frog said. Also, check your fuel pressure, possibly swap the regulator with another one. I'd check timing too, just to be safe.
Old 04-26-2009, 05:50 AM
so even though they are getting fire (wires), it could still be mis firing and bad??
Old 04-26-2009, 06:13 AM
koa
koa's Avatar
Icant wait to see what fixes this. As my car does the same exact thing.
Old 04-26-2009, 06:34 AM
i'm fixing to go buy new plug wires and see if that fixes it. I'll post back later with results. The car does run, and will drive, so I can't see where it would be loosing compression, looks like it wouldnt even run at all.
Could it be the Oxygen sensor?? think that would cause a mis-fire maybe messing up the fuel ratio or something?? ........just a thought
Old 04-26-2009, 07:21 AM
john encarnacion's Avatar
like "sohc" sayed check your check engine lights? injector maybe?!
Old 04-26-2009, 10:13 AM
*Problem Fixed!!*
It was the plug wires. Luckily it was a free fix for me b/c I had bought the wires at Auto Zone and they had a lifetime replacement warranty, so I got them free of charge!!
Old 04-26-2009, 11:44 AM
Dangousity's Avatar
I had the #3 wire pull out of the Distributor cap enough to cause the same problem, When I pulled over it was hanging 3 inches away and the spark was still jumping the gap.
Also I damaged the coil spring when I rebuilt the car last month, ran it without for a week, couldn't really tell, but when I bought a new coil and cap, you could really tell, the arching of the spark across the gap was corroding the thing's fast.
If you guys are having wire problems, I believe those wires really gotta be toasted lol.
Old 04-28-2009, 05:32 PM
koa
koa's Avatar
yup fixed mine too. i guess y8 plugs dont work on a z6
FrankPugg
05-26-2015 03:42 PM
dawndap
02-12-2008 04:19 PM
jthe24kid
04-15-2004 05:03 AM
Acc99ord
12-18-2003 09:42 PM
evergruven
03-10-2002 06:48 PM
Quick Reply: *Urgent* 99 civic sputtering, check engine light flashing!
