d16y5 head with d16y8 head internals
Old 11-21-2016, 05:08 AM
GODzilla15's Avatar
Icon5 d16y5 head with d16y8 head internals
Can I replace my d16y5 head internals with a y8 and what are the parts that I need to change ex. ECU,Distributor etc...
and what are the pros cons thanks
Old 11-21-2016, 05:42 AM
mk378's Avatar
Default Re: d16y5 head with d16y8 head internals
It won't work. First the VTEC-E head has roller rockers and all the others are slider cam followers, so probably what you propose is simply not going to fit.
You really need either a complete set of HX parts, i.e. a true HX, or swap everything (block, head, controls, manifolds) over to non-HX, to have a setup that runs right.
Old 11-21-2016, 11:01 AM
chrysler kid's Avatar
From what I have read the y5 head and y5 pistons were made to each other.
Soo if you put a y8 cylinder head on a y5 block you would suffer a lower compression ratio because of the dished pistons in the y5 block
So you suffer the same fate as all hx models, you stay stock unless you want to do an engine swap.
Old 11-21-2016, 02:20 PM
Fish Twig
tony_2018's Avatar
I believe he wants to switch everything in the y5 head to the y8. What he didn't specify was whether this head will be going on a y8 block on a y5 block.
Old 11-21-2016, 04:07 PM
Technical Hero
HondaPartsHero's Avatar
Yes but you'll need the entire rocker assembly
Old 11-22-2016, 01:26 AM
GODzilla15's Avatar
Yes y5 head with y8 internals I've read some thread here in honda tech that you can swap y5 internals with a y8 and I'm buying a tuneable ECU ,I'm not actually sure if it's recommended to change distributor ,im using it with a y5 block
Old 11-22-2016, 01:39 AM
GODzilla15's Avatar
Some people are saying that the y5 has a better head port than the y8 is it true?. And y5 downside is just the vtec-e and small cam
Old 11-22-2016, 02:28 AM
Technical Hero
Both have the same casting so I doubt there is any porting done from Honda
Old 11-22-2016, 03:48 AM
GODzilla15's Avatar
https://honda-tech.com/forums/group-...squad-1535304/ here's the link to the thread I've just read
**d16y5 uses the same head as a d16y8, only it's rockers and cam are different SO NO SMALL PORTS ON THE y5**
Demerica333
08-21-2008 09:24 PM
hb_guy
01-16-2006 07:31 AM
xci_ed6
12-13-2004 09:57 AM
crashtest Sonny
08-09-2003 02:51 PM
MrIllegalX
30
08-08-2003 02:20 PM
Quick Reply: d16y5 head with d16y8 head internals
