d16 timing belt tensioning question.
Old 11-23-2003, 07:19 PM
aerogant's Avatar
Default d16 timing belt tensioning question.
How often does a timing belt need to be tensioned? Is it a case of just adjusting it when replacing and not touching it again? Should the belt be very tight, or should it have play like an alternator belt? Thanks for your time.
Old 11-23-2003, 07:34 PM
Solbros Owns Me
Evs-One's Avatar
Default Re: d16 timing belt tensioning question. (aerogant)
just once, the leave it. Loosen the tensioner, then rotate the engine so the cam gear moves 3-4 teeth on the belt. This usually tightens the belt enough.
Just use sense....it doesn't need to be crazy tight, but it can't be sloppy either
dleccord
04-13-2020 08:03 AM
airikkCRX
04-02-2010 08:29 AM
djviet2000
04-06-2008 10:55 PM
JDMtype Eg6
02-18-2007 05:45 AM
blayzenazn
02-18-2002 07:51 AM
Quick Reply: d16 timing belt tensioning question.
