D15B variation identifiers
Old 03-15-2017, 12:20 AM
HoodbillyLG's Avatar
Default D15B variation identifiers
K I picked up a D15B but its non vtec....the head stamp leads me to believe its a 94....which supposedly only.came with vtec.....what numbers and where should i be lookin to tell??
Also wierd plate bolted onto the back of the head bout were the solenoid would go remember reading something bout it but cant find the article now what is its purpose??
Old 03-15-2017, 07:00 AM
PHANTOM MENACE
24TEN's Avatar
Default Re: D15B variation identifiers
There are many versions of the D15B so let me just make it easy for you, you basically got the D15B2/7 version of it. Biggest tell tale sign is the spark plug holes are on the intake side of the head (all D-Series VTEC SOHC and all 96-00 regardless of trim level have the spark plug holes on the exhaust side of the head). That plate is a block off plate for the mechanical fuel pump that was once there. That is an indication (I believe) that this was originally set up for a carburetor .
Old 03-15-2017, 07:44 AM
Yeah i just did a bunch of research last night.......i believe cuz of the head stamps is tech a b2....i gotta drive over there and double check but oh well honestly planned on turbo'in it ANYWAYS 😂 just gotta do a couple things first
but thank you very much for your help buddy
Old 03-15-2017, 10:09 AM
Hysterically Calm
TomCat39's Avatar
That D15B is the carb version.
It has the block off plate where the mechanical oil pump attaches to and you can see the lobe on the cam that operated the mechanical oil pump.
The carb version is a non vtec and it's the equivalent of the D15B7 head as far as I could tell.
Old 03-15-2017, 11:29 AM
Attachment 429946
K next question is......do i take the time to track down a jdm vtec 15B head or call it a day and boost it ⁉
Old 03-15-2017, 02:16 PM
Hysterically Calm
TomCat39's Avatar
If that is the original block to that head, then the block is exactly the same as the D15B2 and D15B7. Which means it's pretty weak on the bottom end. Both Boost and Higher RPM is going to be very hard on that bottom end.
The JDM D15B vtec engine has a block more in line with the D16A6 and D16Z6 with larger journal sizes and thicker rods etc.
Really, you best option would be a different engine altogether.
The head could be fun if you want to go back to a carb setup with dual carbs. I think webber made some honda carbs that were beefy. But I would still recommend a different block.
Old 03-16-2017, 09:03 PM
Damn.......aight i guess it will just be my lil band-aid motor for when i gotta do major stuff to my other motors but gotta keep the wheels on the road
thank you all again for your help......im still kinda new to this whole forum thing but this one has been awesomE!!
Old 03-17-2017, 06:35 AM
PHANTOM MENACE
24TEN's Avatar
Rare to see someone having a positive experience on a forum, I'm happy to see you're making the most of it.
Old 03-17-2017, 09:29 AM
thats thing is iv read info on other forums and done research but theres always some jerk feeding false info or tryin to get a laugh......some of us dont have time or patience for that and iv posted a FEW questions on here so far and EVERYBODY that responds is SUPER HELPFUL and have yet to be led wrong
Rover216
07-05-2018 09:19 PM
NEDan
Honda Fit
09-27-2017 04:58 AM
Tim2179
04-24-2009 08:16 AM
irishflame27
11-21-2008 07:28 AM
dylokjai
03-27-2007 01:42 AM
Quick Reply: D15B variation identifiers
