D15B Timing Belt?
Old 06-03-2007, 09:09 PM
unbelievableEG's Avatar
Default D15B Timing Belt?
I am doing the timing belt on my jdm D15B. I bought the D16z6 belt but it seems to have a little to much slack. I read that the D15Z1 (VX) timing belt will work?. (Read it on D-SERIES.ORG)
Or is there a proper belt for the D15b?
Old 06-03-2007, 09:15 PM
Ek Forever y0!
Libertariat's Avatar
Default Re: D15B Timing Belt? (unbelievableEG)
The deck height is different.
I'm no d-hybrid pro, but when you have a mini-me I'm 99% positive you use the timing belt that was used on the doner motor of the head installed.
Old 06-03-2007, 10:04 PM
Bejita's Avatar
The VX timming belt is the proper belt.
The D16 belt has too many teeth. Thats why it's a bit loose.
Old 06-03-2007, 10:55 PM
NTX
Guest
Posts: n/a
Default Re: (Bejita)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bejita &raquo;</TD></TR><TR><TD CLASS="quote">The VX timming belt is the proper belt.
The D16 belt has too many teeth. Thats why it's a bit loose.</TD></TR></TABLE>
Old 06-04-2007, 07:08 PM
Thanks guys.
D15z1 belt works great little on the tight side but none the less works fine.
Old 06-10-2007, 08:54 PM
Metal Head's Avatar
Default Re: (unbelievableEG)
I am also in the market for a new belt, I know he said D15Z1 belt works great, but what other options are there? ok, so u guys said us D15B Vtec guys cant use the 1.6L belts, so we can ONLY use the 1.5L belts as long as there VTEC,RIght?
So I guess i need to find out what d15 motors were VTEC....
Old 06-10-2007, 09:41 PM
humbleg's Avatar
Default Re: (Metal Head)
if its the jdm D15b u have to use the vx belt!!! here is a helpful link to all the other parts for that motor
http://www.d-series.org/forums...32597
Old 06-17-2007, 05:44 AM
Joecivic94's Avatar
Default Re: (humbleg)
I will be doing a b7/D15B vtec mini me and i want to know what timing belt is the correct one, I've read that the D15b vtec head is almost the same as the Z6 head so should i use the z6 timing belt?
Old 06-17-2007, 06:12 AM
Bejita's Avatar
It is the same....not almost.
Old 09-17-2007, 02:52 PM
walker111's Avatar
Would the vx belt work the same for a non VTEC motor?
Old 09-17-2007, 02:53 PM
walker111's Avatar
Default Re: (walker111)
Also, what crank pulley would I use? non vtec
Old 09-26-2007, 08:41 PM
Ch3mik's Avatar
so then the z6 belt wont work then ? Im doing a Y8 head on a jdm d15 block. :/
airikkCRX
04-02-2010 08:29 AM
airikkCRX
02-08-2009 01:52 PM
dcwoodard
10-05-2008 05:29 PM
JDMtype Eg6
02-18-2007 05:45 AM
Benhawk
01-29-2007 11:49 AM
Quick Reply: D15B Timing Belt?
