Collapsing Radiator Hoses
Old 03-20-2014, 06:37 PM
dan.757's Avatar
Default Collapsing Radiator Hoses
Hey guys I have a 1999 Civic Si B16a2 all stock. When my car begins to cool after a drive both the lower and upper radiator hoses collapse. I've searched the forum but cant figure it out. At first the overflow hose was clogged so I cleared it from the radiator all the way to the bottom of the overflow tank when I got home they still collapsed so I slowly released the cap the air hissed and the hoses immediately went back to normal. Next, I replaced my cap (1.1bar/16psi) suspecting the valve was bad but the hoses are still collapsing. I don't think the cap is burping for the overflow because the level isn't changing and its obviously not allowing vacuum for the cool down. Any help is appreciated, thanks.
Old 03-20-2014, 06:40 PM
Former User's Avatar
Default Re: Collapsing Radiator Hoses
Rent the block tester kit from AutoZone to test for a blown head gasket.
Old 03-20-2014, 06:50 PM
dan.757's Avatar
Man I hope that's not it, but thanks I will.
Old 03-20-2014, 06:51 PM
Good luck. You might first try bleeding the cooling system.
https://honda-tech.com/forums/showth...1#post39830585
Old 03-20-2014, 07:11 PM
dan.757's Avatar
Yeah I was in the process but I got side tracked and forgot to turn the heat on, let the fan turn on, and rev the engine. But, I did let the thermostat open and squeezed the hoses with the cap off with no luck.
Old 03-20-2014, 07:15 PM
dan.757's Avatar
I did forget to mention they ONLY collapse when the car is cooling down not while driving or just stopped but a few minutes later.
Old 03-20-2014, 07:32 PM
Do the full bleed procedure and then go from there.
Old 03-20-2014, 07:43 PM
dan.757's Avatar
I will, thanks.
Old 03-21-2014, 11:00 AM
cvcrcr99's Avatar
Follow RonJ, but you can always look into the cap. I am sure he will get to that sooner or later. Many times, the cap isn't letting fluid back into the system during cool down and creating vacuum in the system.
Old 03-21-2014, 11:02 AM
Originally Posted by cvcrcr99
you can always look into the cap...Many times, the cap isn't letting fluid back into the system during cool down and creating vacuum in the system.
Old 03-26-2014, 08:24 AM
dan.757's Avatar
Sorry to revive an old thread, but just wanted to come back with an answer for anybody who is having the same problem. I fixed the problem by turning the new cap the opposite way so the words would be upside down if you were facing the engine bay and tried not to overtighten, test drove the car 3 times and it somehow fixed itself. I also went ahead and did a coolant flush because the coolant that was in the car (just got the car not that long ago) had drop-out from an over concentration of coolant to water creating a "green goo" substance which would clog the overflow hose sometimes. The car is running great and even a few degree cooler, thanks for everyone's help.
Tic55
Honda Civic (2001 - 2005)
16
09-01-2018 12:13 AM
thechineseone
03-16-2009 09:33 AM
Ritchie
07-02-2007 08:22 PM
dmxsoulja3
12-16-2004 03:07 PM
Quick Reply: Collapsing Radiator Hoses
