Code P0141, Need help with this one
Old 07-17-2010, 04:49 PM
Dr. Willy's Avatar
Default Code P0141, Need help with this one
Okay so my car was throwing a p0420 for a while, which i figured was the cat. I decided to start with the 02 sensor just to see. Replaced the sensor and now i get a p0141 code after the car idels for about 30 secs- 1 min. Doesnt matter how many times i reset it with my scan tool, just comes right back. Do you guys still think its the cat? ive tried 2 other o2 sensors, including the one that i replaced in the first place and i still just get the p0141 code, it wont throw a p0420 anymore at all.
Old 07-17-2010, 04:56 PM
Resident Gearhead
BryanM.'s Avatar
Default Re: Code P0141, Need help with this one
P0141 is O2 sensor heater circuit malf. right? I don't have my manual handy.
If so it sounds like a wiring issue.
inbeforeRonJ@HT
Old 07-17-2010, 04:59 PM
delsolproblems's Avatar
You might double check the wires. You may have switched two wires when you hooked up the first new sensor and then copied it with the second. Alternatively, you may have tugged on one of the heater wires during installation, pulling it out of the next connector on the way to the ECU. Try setting a meter to ohms and check the resistance of each of the four sensor wires between the wires at the ECU and the ones at the O2 sensor. Open the passenger door, pierce a wire at the ecu with one probe and the corresponding wire coming out of the sensor with the other probe.
Old 07-17-2010, 05:46 PM
Dr. Willy's Avatar
well this is a brand new denso o2 sensor, with a plug on the end so i didnt wire it up it came wired up. i will try the ohm thing, when i do scan it with my scanner it says not all readiness test complete, what does that mean?
Old 07-17-2010, 05:57 PM
Dr. Willy's Avatar
i am also going to try and switching the y7 cat with my gf's y7 cat to see if that solves the problem.
Old 07-18-2010, 04:31 AM
The heater malfunction code will not be fixed by replacing the cat. The not all readiness tests complete message means that due to the problem with the O2 sensor, the scanner was unable to determine that your vehicle was ready for an emissions test.
Old 07-18-2010, 04:46 AM
Former User's Avatar
P0141 indicates a problem with the secondary O2 sensor heater element not the cat. Did you replace the primary or secondary O2 sensor?
Old 07-18-2010, 09:07 AM
Dr. Willy's Avatar
i replaced the secondary 02 sensor, what i dont understand is why it was throwing the code for the cat, like the cat was bad at first but now it is not.
Old 07-18-2010, 01:18 PM
It can take a little time for code 0420 to pop up. If you let the car sit for a time while you work on it, the cat can continue catalyzing compounds inside of it so that there is less to absorb by the time you turn the car on again. With less crap inside it, it can work better for awhile until it gets coated again. A perfectly working cat should keep up with the exhaust, catalyzing compounds as quickly as they flow through but a failing cat can allow more build-up because it isn't keeping up with the exhaust. It all depends on how bad the cat is.
Old 07-20-2010, 12:45 PM
Dr. Willy's Avatar
okay, so here is what i found out, if the car is cold and i start it up, it throws the cel for po141 after the car has ran for about 30 sec, if i then take the car out and drive it and it gets warmed up, then delete the cel, it doesnt come back, until the car cools back down and is started again, im guessing possibly bad ecu is the only thing i can think of i checked wiring and everything is fine there.
Old 07-20-2010, 12:54 PM
Do you measure 10-40 Ohms across terminals 3 and 4 (heater element) of the new O2 sensor?
Old 07-20-2010, 05:05 PM
Dr. Willy's Avatar
i just got home, keep in mind the car was hot so i dont know if this makes a difference? i had my voltimeter set to 200k ohms rating, not sure if this is the right setting either? but i had 69.3 was my reading between 3 and 4, im assuming it was 3 and 4, the other 2 colors were black which i figure was ground, and these were the other 2 wires that were colored. Let me know what you think, thanks
Old 07-20-2010, 05:09 PM
That's too high and may indicate the problem. Measure again when the exhaust system is cooler.
What year/trim?
Old 07-20-2010, 05:10 PM
Dr. Willy's Avatar
its a 2000 dx, and i will try in a bit once it cools off. Thanks ron
Old 07-20-2010, 05:20 PM
You chose the 200,000 Ohm scale. Instead, you should select the lowest scale, such as 20 Ohms or 200 Ohms.
...69.3 was my reading between 3 and 4, im assuming it was 3 and 4, the other 2 colors were black which i figure was ground, and these were the other 2 wires that were colored. Let me know what you think, thanks
The two black wires actually correspond to terminals 3 and 4. Terminals 1 and 2 have white and lt green wires.
Repeat the Ohm measurement between the correct terminals (for the two black wires) and use the lowest Ohm scale.
Old 07-20-2010, 09:24 PM
Dr. Willy's Avatar
i will do tomorrow when i get home from work and will report back
Old 07-21-2010, 03:17 PM
Dr. Willy's Avatar
okay on termanals 3 and 4 (the two black wires) i am messuring 4.6-4.8 on the 200 ohms setting. Im guessing this is withing range?
Old 07-21-2010, 05:27 PM
Tico Loco's Avatar
Hi I am form Costa Rica. I am a amateur engine builder and I race my Honda Civic Ex D16z6 engine.
You can burned the sensor with the ohms test. Be sure to measure the ohms at the heater wires, if you try to ohms test on the sensor wires you can burned the sensor.
The sprimary sensor control the fuel mix, the second is to verify the cats eficiency. In some vehicles is your second sensor is not working could give a wrong code, like a bad cat.
Check the volts coming from the plug in the heater wires from the wiring system. If their is no volt, the heater do not work.
Old 07-21-2010, 06:46 PM
The resistance is too low (4.6-4.8 Ohms). It should be 10-40 Ohms = bad O2 sensor.
Old 07-21-2010, 06:48 PM
Dr. Willy's Avatar
i actually think i found the problem, the o2 sensor i have is a front sensor, im guess it wont read right as the 2nd sensor cause i put the old o2 sensor back, and no more cel.
YaBoiTHiZZ
12
03-28-2012 08:10 PM
blaze the chemi
06-20-2005 12:20 PM
VTEC-DA
07-30-2003 05:55 AM
1.8EG-T
10-28-2001 05:03 AM
Quick Reply: Code P0141, Need help with this one
