Code 43 on 95 Civic
Old 11-11-2010, 02:12 PM
95civickilla's Avatar
Default Code 43 on 95 Civic
Ok how can i fix this code i heard is one of the worst codes on the honda thing i know a lot of honda but this code its pissing me off my car is a 95 civic with the d16z6 engine rebuild but that code is pissing me off what could it be or what should i look for. no mods at all
Old 11-11-2010, 02:38 PM
Former User's Avatar
Default Re: code 43 on 95 civic fuel supply
If you don't have any performance problems, check the O2 sensor.
Old 11-11-2010, 02:45 PM
Default Re: Code 43 on 95 Civic
WELL I DONT KNOW THATS THE WAY I BOUGHT IT SO I DONT KNOW IF ITS THE SAME WAY MY CAR IS GOING TO RESPONSE OR IT NEEDS MORE POWER I DONT KNOW BUT ILL CHECK THE O2 SENSOR HOW CAN I CHECKED IT
Old 11-11-2010, 02:52 PM
No need for all caps.
Have you cleared the ECU to see whether the code returns?
Old 11-11-2010, 02:56 PM
OK I JUST DISCONNECTED IT AND PLUG IT BACK IN I CHECK THE CODES AND NO CODES WHERE BLINKING MY CHECK ENGINE LIGHT WAS ON AND MY SRS START IT BLINKING AND NEVER STOP ( I PLUG THE PAPERCLIP TO THE LITTLE CONNECTOR BELOW THE GLOVE COMPARTMENT
Old 11-11-2010, 03:05 PM
TURN OFF THE ALL CAPS ON YOUR KEYBOARD.
The SRS light blinks an SRS code with the service connector jumped when there is an airbag circuit problem.
Now drive the car to see whether code 43 returns.
Old 11-11-2010, 04:14 PM
yeah it blinks but never stops blinking the code 43 disappeer what could it be i heard it was a faulty ecu.
Old 11-11-2010, 04:18 PM
With the service connector jumped, are you saying the CEL is blinking a new code or that the SRS light is blinking?
Old 11-11-2010, 04:24 PM
no the srs light is blinking all the time no pauses or anything could it be a faulty ecu
Old 11-11-2010, 04:27 PM
Only with the service connector jumped, right? If you unjump the connector, does the SRS light just remain on steady.
Old 11-11-2010, 04:30 PM
no it turns off if i disconnected the srs and the check engine
Old 11-11-2010, 04:32 PM
If CEL code 43 does not return, then you are good to go.
For the SRS light, did someone remove an airbag?
Old 11-11-2010, 04:35 PM
nope is intact and the code 43 dosent appear but still messing up
Old 11-11-2010, 04:45 PM
mr2passat801's Avatar
The SRS blinks on them. Mine does at least. And it goes directly back off... And if you say the car is still messing up WTF do you mean???
Old 11-11-2010, 05:02 PM
ok my srs light blinks and dont stop when i jumped the service connector to check my ecu. and my car still turns off by itself everytime i press the gas pedal and when is release it shuts off so i need to press the gas pedal all the time even to brake or it will turn off and i cant floor it once in a while cuz it wont rev so i need to press the gas little by little until i cross the 1200rpm range but that happens once in a while
Old 11-11-2010, 05:11 PM
How old are the plugs, wires, cap, and rotor? Have you checked the mechanical and ignition timings.
Old 11-11-2010, 05:12 PM
i check that already the timing and nothing and mechanical what do you mean with that
Old 11-11-2010, 05:15 PM
Did you do this:
Old 11-11-2010, 05:17 PM
Old 11-11-2010, 05:27 PM
ok when i do that connect the serivice connector does any light has to blink after connecting it
Old 11-11-2010, 07:15 PM
18237sja's Avatar
mod rage
Old 11-11-2010, 07:21 PM
whats mod rage
Kris's turbo
04-10-2009 07:24 AM
EK9_GRL
10-08-2007 12:03 PM
dro93si
02-24-2007 03:32 PM
ProLineDesigns
03-28-2006 05:20 AM
Yellow Dragon
08-05-2001 01:04 PM
Quick Reply: Code 43 on 95 Civic
