Code 41: Primary Oxygen Sensor Heater, Car bogs when accelerating
Old 08-25-2005, 08:52 PM
JibOnALib's Avatar
Default Code 41: Primary Oxygen Sensor Heater, Car bogs when accelerating
Hi, I just swapped a gsr into my 94 Si, and I'm throwing only a code 41, when i'm at low rpms and get on it a little the car bogs down and then i let off and slowly accelerate its fine. The o2 sensor has quite a bit of mile on it, do you think a bad o2 could cause the car to bog like it does when you accelerate?
Thanks,
Keith
Old 08-25-2005, 08:54 PM
MugenHonda's Avatar
Location: With my POS D15B2, Whereever whenever, United States
Default Re: Code 41: Primary Oxygen Sensor Heater, Car bogs when accelerating (JibOnALib)
Change the o2 sensor and find out, and yes the o2 sensor can cause hesitation
EK k kay's Avatar
Default Re: Code 41: Primary Oxygen Sensor Heater, Car bogs when accelerating (MugenHonda)
Check the primary o2 sensor connection. Might have gotten loose somehow. If that doesn't work just replace it.
924drb20
12-14-2010 10:36 AM
Bossup!
09-09-2009 07:35 PM
claytonsmith
10
05-16-2006 12:01 PM
draxxus07
10-13-2005 05:41 PM
Quick Reply: Code 41: Primary Oxygen Sensor Heater, Car bogs when accelerating
