clutch going out
Old 04-09-2012, 01:43 PM
jrhcivak's Avatar
Default clutch going out
Soo my tranny isnt going into gear at all randomly.
today, i had the car in reverse parked(broken ebrake) and started the car whith the clutch in, like your suposed to do, and the car jumped bawkard like i dumped the clutch or something, and died..
once the car warms up, if i put it in first (which is very hard), i can hear a metalic grinding noise coming from the tranny. sometimes it literally will not go into gear. if i try forcing it in, the revs drop a little bit. i never completely force it in. if i just free rev it, then put it into gear, that seems to help.
the thing that really confuses me is that the clutch pedal feels fine. its still decently firm and you dont have to pull it out real far to engage.
its just really ****ed up and idk why. im gunna order a new clutch this week depending on what you on here say.
thanks again for any help.
Old 04-09-2012, 01:45 PM
DELshaneSOL's Avatar
Default Re: clutch going out
sounds to be the problem
clutch fluid full?
how was it before?
did you tranny ever grind in any gear b4
Old 04-09-2012, 01:48 PM
vitamin_c95's Avatar
Try pumping up the pedal several times, then try and shift into gear. Another good check would be to bleed the clutch lines. Also check color of clutch fluid. I had a similar issue, not quite as bad as yours. My clutch lines had a small leak and would bleed down
By the way, what year and model car?
Old 04-09-2012, 02:06 PM
jrhcivak's Avatar
Sorry. 93 eg with b18b1.
Not to sound like a dumbass but how do I check clutch fluid? Its my first Honda and have never had to check clutch fluid anyway.
And I do pump the clutch and it kinda helps.
And before it got this bad, second was just really hard to get into. Like if I revved it higher than 3500 it would hit a wall going into second. Just wouldn't go in.
Old 04-09-2012, 02:09 PM
Arthas's Avatar
I am 99% sure its your transmission fluid, that would be the first step to check. I would stop driving the car until you change the fluid so you dont do anymore damage to the gears.
Go to your local Honda dealer and purchase 2 quarts of Honda manual transmission fluid, theyll be about $10 each. Then get a funnel with a 90 degree bend on it.
Follow the steps in this tutorial and report back with your findings.
https://honda-tech.com/forums/showth...smission+fluid
Old 04-09-2012, 02:11 PM
Silvertune's Avatar
Sounds like a wrecked tranny to me.
Old 04-09-2012, 02:20 PM
RT_NEWYORK's Avatar
I dont kno alot of about cars or vehicles for that matter. But one thing I do know is cars need all sorts of fluid, oil, lubricants. When they dont have their fluids they act up. Definitely check your tranny fluid.
Old 04-09-2012, 02:28 PM
Arthas's Avatar
Gears dont start grinding when your clutch goes out, they just slip. Replace your tranny fluid and call ti a day.
Old 04-09-2012, 04:02 PM
Seagull Management
94EG8's Avatar
They do when the clutch wont disengage because some part of the hydraulic system is bad or the disc spit a spring.
If it jumped ahead/back in gear with the clutch in there's something wrong with the clutch. It's grinding when you try to put it in gear because the clutch isn't releasing. If the pedal feels good it makes me suspect the disc spit a spring, but check the master and slave cylinder first since they're easy to get at and a lot cheaper. If they're leaking replace them and bleed the clutch.
Old 04-10-2012, 10:15 AM
jrhcivak's Avatar
When I drain the old fluid, how much will come out? 2 quarts?
Old 04-10-2012, 10:28 AM
I'd say about 2.5
Old 04-10-2012, 11:16 AM
jrhcivak's Avatar
Soo should I buy 2 or 3 quarts of new fluid?
Old 04-10-2012, 11:26 AM
been there done that
doood's Avatar
Trans fluid won't prevent the car from going into gear. I had a similar problem with my rsx and it turns out my master cylinder was busted and leaking. Check that and the slave first.
Old 04-10-2012, 11:43 AM
I mentioned To check the fluid so I thought he did that
Old 04-10-2012, 12:08 PM
Arthas's Avatar
About, just get 2 quarts.
Thats funny. After my Y8 swap was completed the car wouldnt go into gear. It didnt have trans fluid and after I added 2 quarts, it shifted as smooth as butter.
Old 04-10-2012, 12:17 PM
doood's Avatar
Well obviously if there's no fluid to begin with then yes you'll have problems. But the problems the op is describing sounds like a hydraulic system problem.
Old 04-10-2012, 12:28 PM
Seagull Management
94EG8's Avatar
None. Transmission fluid isn't going to do anything for you. You have a clutch issue.
Old 04-11-2012, 03:55 PM
As for clutch fluid, its DOT 3 (brake fluid). As some posted above, I am leaning towards hydraulic issues. EIther air in the lines, bad fluid, or a failing slave/clutch cylinder. What color is the fluid in the clutch master cyl reservoir? It should be clear-ish or a slightly darker hint of brown. The darker the color, the worse condition it is.
Bizzle5OH3
Transmission & Drivetrain
05-13-2011 03:05 PM
antoneexx
04-06-2007 01:50 PM
futurefastguy
10-13-2006 10:32 AM
PrettyFastRide
13
07-13-2006 06:30 AM
green98civic
13
06-28-2003 10:13 AM
Quick Reply: clutch going out
