Clunk!
Old 03-16-2007, 10:05 AM
ahemming06's Avatar
Default Clunk!
Trying to diagnose this clunk noise and I think it could be coming from possible the front suspension.
I replaced all motor mounts with avid racing motor mounts, so the motor doesnt move at all anymore. Also replaced brakes and rotors bran new so theres no more vibration from the old warped rotors. But still every once in awhile when I brake harder than normal I can still hear a (CLUNK) noise and seem to figure out what the hell it is.
Could it possibly be bad front LCA's? I know theres no way to answer this but just looking for suggestions on something common I havent already tried to work on?
Thanks in advance.
Old 03-16-2007, 10:17 AM
Forty04's Avatar
Default Re: Clunk! (ahemming06)
inspect the axles/boots for any visible damage?
Old 03-16-2007, 10:23 AM
ahemming06's Avatar
Default Re: Clunk! (Forty04)
Also have new OEM integra gsr axles as well.
I have a bone stock 96 gsr swap into a 95 civic ex coupe.
Old 03-16-2007, 10:29 AM
ek_chris's Avatar
sounds like control arm bushings to me.
Old 03-16-2007, 10:41 AM
EL Vap133's Avatar
Put the car on jack stands and inspect it. Shake some things around under the car to see if you can find what is loose. I would take off the wheels too so that you can check the brake components.
Old 03-16-2007, 10:57 AM
ahemming06's Avatar
Default Re: (ek_chris)
Definitely will do. To be honest that is the answer I was looking for, I never thought of it before but I think I might need to upgrade these old LCA's with 180,000 miles on them. Will probably go with skunk 2 or something and then see if the (CLUNK) is gone after that.
Thanks for the input guys, I appreciate it.
Old 03-16-2007, 11:15 AM
EL Vap133's Avatar
Default Re: (ahemming06)
Hope you find the clunk.
EG6lovin06
10-03-2013 01:15 PM
KhmerdudeSiR
12
11-13-2008 06:23 PM
russianswty
07-06-2007 10:33 AM
imskatencrzy
10-05-2006 08:18 AM
ridestrt
05-18-2004 09:27 AM
Quick Reply: Clunk!
