Close Up pic of top of D16Y8 intake mani vacuum lines
Old 07-19-2014, 10:06 PM
nuclidex's Avatar
Default Close Up pic of top of D16Y8 intake mani vacuum lines
I am having a hell of a time being sure which vacuum lines go where.
It all started with my "high idle" issue when I purchased the car.
High idle, random idle, hesitation/jerkiness when pressing the throttle.
I am going down the list and the next thing is the checking for proper hose routing and then leaks..
I have this schematic, but it is not 100% clear, as I am not extremely familiar with Hondas.
http://repairguide.autozone.com/znet...528018f91e.gif
Anyone with a pic, especially anything pertaining to the lines that go from the intake mani to airbox, as well as the lines that run around the fuel rail.
I am working with #17 and the related.
Thanks ahead of time.
PS no google didnt have many good images to work with.
Old 07-19-2014, 10:08 PM
shotoutacc0rd's Avatar
Default Re: Close Up pic of top of D16Y8 intake mani vacuum lines
You think a Honda is bad!? Look up the vacuum diagram for a Mazda 1.3b
now dont feel bad because you dont have a problem like that!
have you checked the factory service manual? Or even a Haynes manual?
Old 07-19-2014, 11:53 PM
nuclidex's Avatar
ROFL thanks for making me feel better...
I am still chugging away at it... the line to the purge control solenoid was plugged at the upper intake, and the purge control side was just open. I removed the plug and ran a new line..
From my evap control canister there is no purge joint at the end of the line. Could this cause problems like high idle, besides throwing codes?
Old 07-20-2014, 12:18 AM
Global Moderator
tech8's Avatar
See if this thread may help:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/1998-civic-ex-d16y8-motor-replacement-2573250/
Old 07-20-2014, 04:30 AM
Technical Hero
HondaPartsHero's Avatar
Year, make and model?
96-98 Honda Civic EX
99-00 Honda Civic EX
Rexcar69
02-15-2013 07:38 AM
accordianex
06-17-2012 04:32 PM
AztecEGhatch
17
12-23-2011 03:14 PM
DevinJM
03-01-2010 11:24 AM
Quick Reply: Close Up pic of top of D16Y8 intake mani vacuum lines
