Check engine light
Old 02-22-2010, 09:09 AM
Yonick90's Avatar
Default Check engine light
Just did a auto to manual tranny swap on my 95 honda civic
when i started the car i had a DTC code 2-2 and my SRS light was on...
looked up code 2-2 and its a SRS problem, this happen to anyone? dont even know where to start looking
Old 02-22-2010, 09:31 AM
dpetro1's Avatar
Default Re: Check engine light
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
are you saying that you followed this and got code 22? im confused on your question
Old 02-25-2010, 07:23 AM
Yonick90's Avatar
no i jumped the wires and got 2 fast blinks and 2 slow, so thats CEL 2-2 for SRS... but it wasnt there before i did my auto to manual swap... so idk where to start looking to fix the SRS problem
Old 02-25-2010, 08:16 AM
dpetro1's Avatar
your check engine light does not come on for the airbag system. the SRS light would illuminate if there was a problem with that system.
Old 03-01-2010, 08:43 AM
Yonick90's Avatar
my SRS light is illuminated, and when i went to alldata.com to check code 2-2 it was for SRS problem. so both lights are on for the same thing, idk where to start looking for a problem like that
Old 03-01-2010, 09:55 AM
apexi_rsx's Avatar
2 fast blinks then 2 slow blinks would mean its 2 and 20
Old 03-02-2010, 09:47 AM
Yonick90's Avatar
i checked the list and 22 is for a vtech pressure valvle... my car is not vtech tho. when i did the auto to manual swap tho i just cut a wire to the automatic solenoid, think that would have anything to do with it?
Old 03-02-2010, 11:21 AM
HCivExoo's Avatar
what manual ECU did you put in to replace your old auto ECU? if it is a P28 for instance that is a VTEC ecu on a non VTEC harness and could be causing your CEL. i would expect other codes as well though.
cutting your auto trans. solenoid wires would not cause this.
Old 03-02-2010, 06:24 PM
Yonick90's Avatar
oh yeah good point, i did put in a P28 so that makes sense now thx man. i just gotta figure out this SRS problem now
benwadb1
06-28-2008 05:50 PM
haynesbc
03-02-2008 12:22 PM
Nikoli
05-03-2004 11:59 AM
eL
10-25-2003 05:25 AM
kayoken
02-05-2003 08:12 PM
Quick Reply: Check engine light
