OBD2 B16 -- can a throttle body sensor make a car run slow
Old 06-07-2011, 07:18 PM
jdmeg6honda's Avatar
Default OBD2 B16 -- can a throttle body sensor make a car run slow
i installed a skunk 2 throttle body and i cant get it to the stock spec and the car runs like slow sometime it runs good but the check engine lights stay on
Old 06-07-2011, 07:25 PM
Former User's Avatar
Default Re: can a throttle body sensor make a car run slow
Code?
Old 06-07-2011, 10:33 PM
THC07's Avatar
seriously!
your light is on and you're asking questions?
Old 06-08-2011, 12:23 AM
the code are air idel control and throttle body sensor first the air idel control code pop up and ran slow and stupid and now the throttle body sensor.. and seriously if the check engine lights come on doesnt make the car go slow all the time it some time make it run rich and better duhh..
Old 06-08-2011, 02:27 AM
Resident Gearhead
BryanM.'s Avatar
lol no
Fix the CEL codes and go from there.
Old 06-08-2011, 06:21 AM
sohctodohc's Avatar
your grammar is that of a 6 year old...
Old 06-08-2011, 08:34 AM
THC07's Avatar
More fuel does NOT mean its going to make your car faster.
Last edited by Former User; 06-08-2011 at 08:51 AM. Reason: Flaming posts are forbidden in tech forums. Please review the forum rules.
Old 06-08-2011, 08:44 AM
that_boy_sammy's Avatar
Your throttle position sensor? From when I installed it theres only one way to put it on. And if you bought a skunk 2 tb it is already calibrated. Find out your cel code, fix it, and it will not run sluggish.
Old 06-08-2011, 09:35 AM
Crashtestdummy's Avatar
Old 06-08-2011, 09:51 AM
Please do not derail tech threads with off topic comments. While I don't classify these posts as flaming, such comments should also be accompanied by an attempt to help with the tech problem. Otherwise, they don't serve a very good purpose.
Old 06-08-2011, 12:49 PM
the skunk 2 throttle body came with no sensor meaning no map or throttle body sensor and i put on all the sensor but the throttlebody sensor might be wrong bcuz i couldnt get it to stock spec...
Old 06-08-2011, 01:00 PM
You need to calibrate output voltages from the TPS. Also immediately pull the CEL codes. Click the CEL link in my signature.
Old 06-08-2011, 01:20 PM
its a obd 2 b16 so whats the output voltage on that thing? and how do i know if i got a bad throttle body sensor?
Old 06-08-2011, 01:23 PM
0.5V closed throttle, 4.5V WOT
Seriously, before you make anymore posts, jump the service connector to pull the codes. Then post them.
What car?
Old 06-09-2011, 10:33 AM
Default Re: OBD2 B16 -- can a throttle body sensor make a car run slow
ok i cant find the jumper wire so i used my obd 2 scanner tool and the code are tps and air idle control...
ok so this is what i did changed to a brand new air idle control and the adjust the tps.
this is how i did it turn the car to on position adjust w.o.t 4.50v and closed was 0.32 volts. and i turn the car on and it was still the same 0.32 i adjust the idle screw on the throttle body and no luck am i doing something wrong?
Old 06-09-2011, 01:20 PM
Post the two OBD2 codes.
Or are the codes now gone?
The correct calibration procedure is to adjust the voltage to 0.5V at closed throttle and then to check that the voltage is around 4.5V at WOT.
Old 06-10-2011, 11:26 AM
i pulled off the battery cable so the codes is gone but will return in a few days ..
so let me get this rite i gotta check voltage at closed first then w.o.t and not at w.o.t then closed idle?
ok imma try closed first then w.o.t
Old 06-10-2011, 01:25 PM
Yes. First adjust closed to 0.5V and then just check the WOT voltage.
Old 06-15-2011, 07:24 AM
THC07's Avatar
How are you adjusting your TPS?
an .45v closed and 4.5v WOT is probably the best you will be able to get.
just askin; you did change the TB gasket with a new one when you installed the Sk2 TB, yea?
2005del*6*
Honda CR-V & Element
02-11-2013 04:10 PM
SkyliteCustomz
Honda Civic (2001 - 2005)
11-12-2007 01:59 PM
b18c1wes
12-07-2004 02:50 PM
SuzukaBlueAP2
10-16-2003 02:39 PM
D1ANCER
03-27-2002 06:06 PM
Quick Reply: OBD2 B16 -- can a throttle body sensor make a car run slow
