Car wont start after raining days?
Old 05-28-2008, 10:23 AM
blu3g's Avatar
Default Car wont start after raining days?
Okay guys here's the deal. After raining day/night my 93 civic lx (auto) wont crank over. I can crank it, but it wont start. I've replaced the cap, coil, plugs, wires, main relay and it wont crank over. After leaving it sit in the sun for about 8 hrs or so it'll start right back up. This problem only happens after raining days. What I notice is that the fuel pump won't prime when the car wont start. Those days when it does work the fuel pump is priming. I don't think it would be a bad fuel pump because it was, then it wouldn't be working some days and not working some days. Any tip would be nice because i'm completely lost on this one
thanks in advance
Old 05-28-2008, 02:52 PM
blu3g's Avatar
help anyone?
Old 05-28-2008, 02:55 PM
bigsyke's Avatar
Make sure the rubber boots on your fuel pump connectors are fully covering the the connections.
After that check the main relay. I have taken a pressure washer to my fuel pump access cover and then even a few shots to the top of the fuel tank as well. Starts right up. Something is grounding out.
Old 05-28-2008, 05:42 PM
jayjaythejet's Avatar
check your dissy cover. it may me cracked. when it rains it may let moisture in.
Old 05-28-2008, 05:44 PM
Default Re: (jayjaythejet)
nevermind i didn't read all of it
Old 05-28-2008, 06:21 PM
z6hatchboy's Avatar
Default Re: (blu3g)
Try checking your grounds too, its a possibility.
Old 05-29-2008, 05:14 PM
blu3g's Avatar
where is the ground for the fuel pump?
Old 05-29-2008, 05:18 PM
OMGWTFBBQ!'s Avatar
Default Re: (blu3g)
On the fuel pump assembly in the gas tank.
Elijahdaniel
02-27-2016 07:07 PM
Champs32
15
08-30-2010 02:17 PM
nub_pwn
14
01-07-2007 03:30 PM
LilMissCrystal81
11-19-2004 11:26 AM
Quick Reply: Car wont start after raining days?
