Car stalls when clutch is pushed in.
#29
Re: Car stalls when clutch is pushed in.
Unplug the 2nd O2 sensor and turn the key to ON(II). One of the two heater terminals in the wire harness side connector should have battery voltage to body ground and to the other terminal.
#30
For the record, it's P0141, not PO141.
http://www.obd-codes.com/p0141
If you want to do it the right way, test the plugs on your O2 sensor harness. If you want to be lazy, just replace the secondary O2 sensor.
#31
#33
Well, new symptom. Car has completely stopped stalling, and all this morning had a perfect idle of around 800. Well now when I come to a stop the idle will go down real low, and then slowly come back up to 800.
Any more ideas?
@ Ron, I looked up a diagram for how to change my engine idle but I don't have access to a timing light, nor do I know how to use one. So, for now, I'm trying to rule out every other possibility.
Thanks to everyone for all their help so far with this issue.
Any more ideas?
#35
#37
The Grumpiest
https://honda-tech.com/forums/tech-misc-15/diy-how-calibrating-voltage-your-tps-sensor-2947986/
Don't know why that isn't in the FAQs.
#38
https://honda-tech.com/forums/showthread.php?t=2947986
But thanks man, I'll definitely look into it. Even if this isn't my problem, it still sounds like a good thing to do.
#39
Heyy Im new in here I have the same problem with my Honda Prelude did you ever fix your problem I seriously don't know how the clutch has anything to do with the o2 sensor. Thanks
#40
rleonekc
05-30-2007 07:20 PM
