Car stall after warm up when rpms drop from clutch press
Old 07-14-2010, 08:11 AM
neoc03's Avatar
Default Car stall after warm up when rpms drop from clutch press
Going to try to give as much detail as possible here.
Car is a Turbo 2000 Honda Civic SI
Running eCtune map that has been treating me just fine for the last year
Car was recently in the shop for a headgasket. Battery died while sitting and had a cell in the batter go bad.
Problem:
Car runs great and starts right up and doesn't overheat. However once it reaches operating temperature whenever I press in the clutch to come to a stop when the RPMs drop they don't catch at the idle speed where they should. Instead it will drop to 500 or less and 8 times out of 10 it will cut off. Even if it manages to stay alive there is obvious surge, but not your typical honda surge this is from 600-850 rpms. The car sounds like it is struggling to stay alive. The problem is for sure in the RPM drop because when I shift out of gear early and use the throttle to gradually take the RPMs down instead of letting them just drop I can keep it from cutting off usually.
So any ideas?
Old 07-14-2010, 09:03 AM
Former User's Avatar
Default Re: Car stall after warm up when rpms drop from clutch press
First try cleaning the IACV and bleeding the cooling system. Any CEL codes?
The bleeding procedure may take 20-30 minutes:
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push the dash heater lever/**** to MAX heat.
3) Follow the directions in the diagram below
Old 07-14-2010, 09:37 AM
neoc03's Avatar
It has already been bled. I haven't checked the IACV yet I just hate dealing with it being so cramped back there. Will check that today. No CELs. Just curious, but why would a air bubble in the cooling system affect this?
Old 07-14-2010, 09:48 AM
Idle speed is in part controlled by the coolant temp signal sent to the ECU from the 2-wire ECT sensor under the distributor. Air trapped in the cooling system can cause the ECT sensor to sense and send variable erroneous temp signals to the ECU, causing a fluctuating idle.
You might want to bleed the system again as detailed in my earlier post.
Does the CEL work?
Old 07-14-2010, 10:30 AM
neoc03's Avatar
Wow great information. I didn't know that. I will bleed again today. Thanks for your help. Yeah CEL works.
Old 08-30-2012, 09:18 AM
Gizzi333's Avatar
wht was the problem? im having the same issue
ephengthirath
06-05-2009 11:23 PM
skata89
04-06-2007 08:39 AM
jxkim89
12-21-2006 09:28 PM
OMG B16
11-19-2005 06:25 PM
HOTSHOT-H22A
05-06-2005 04:10 PM
Quick Reply: Car stall after warm up when rpms drop from clutch press
