Car shaking.. still waiting for an alignment
Old 09-23-2005, 11:39 AM
JDMlyfestyle's Avatar
Default Car shaking.. still waiting for an alignment
I just recently replaced my inner and outer tie rods. and i was driving the car today to get an alignment the steering wheel was shaking quite a bit would a bad alignment cause this i just wanna be sure there is no other problems
Old 09-23-2005, 11:48 AM
MugenHonda's Avatar
Location: With my POS D15B2, Whereever whenever, United States
Default Re: Car shaking.. still waiting for an alignment (JDMlyfestyle)
Three things
1)alignment
2)Bad tires
3)Steering column
It can be a combination of both and vice versa, its you're deal
AlpineInstaller's Avatar
Bad alignment, bad balancing, and warped rotors (if it increases during braking)
Old 09-23-2005, 11:50 AM
Tires just balanced, New Wheel bearings, New pads and rotors, new inner & outer tie rods, Ball joints. i need an alignment bad cause the steering wheel is way off. so im just going off the assumption its the alignment
Old 09-23-2005, 11:51 AM
its fine when im cruising on highways and ect. just at WOT
Old 09-23-2005, 12:02 PM
Default Re: (JDMlyfestyle)
Get the alignment... then come back. I doubt it's anything else. But let us know if the problem is still there.
HTH
Old 09-23-2005, 01:37 PM
ekmotorfiend's Avatar
check your break your steerin wheel will shake if you need a brake job or if you lugs are loose. but it will pull if you need to get it aligned
Old 09-23-2005, 01:40 PM
Maness's Avatar
Default Re: Car shaking.. still waiting for an alignment (ejmotorfiend)
I had that. So I got my alignment.
"Hey your right front axle needs replacement."
Got that fixed.
"Oh yeah, that squeeling, thats your breaks needing replacing, and we'll resurface your rotors."
But with how I drive, its probably my tires.
So it could very well be your tires.
Old 09-23-2005, 02:07 PM
10secwantabe's Avatar
Why did you do all this?
Old 09-23-2005, 03:48 PM
Because i was tired of replacing stuff and when i decided to do my suspension i did replaced everything just for my reassurance.
BTW the alignment fixed the shaking problem
Old 09-24-2005, 03:45 AM
If you had to force the axle or the wheel bearing you may have disturbed the bearing this would cause the same effect.
Old 09-26-2005, 09:12 PM
Glad to see alignment fixed the problem
Ohbebe75
10-24-2015 07:50 AM
Corksil
10-14-2009 05:37 PM
thewrai6th
Suspension & Brakes
17
01-17-2009 06:15 PM
boots420
05-09-2007 08:57 PM
teewhy55
12-22-2004 09:36 PM
Quick Reply: Car shaking.. still waiting for an alignment
