Replaced rear wheel hub/bearing assembly very noisy
Old 01-14-2013, 12:01 PM
TeeO's Avatar
Default Replaced rear wheel hub/bearing assembly very noisy
I replaced my driver side rear wheel hub/bearing assembly on my 99 Civic Si this weekend, and after fighting to get the race off the spindle I wrapped things up nicely. Today to and from work I was getting what I would call very loud road noise from that wheel. It started noticeably at about 50 mph and became very obvious/loud at 65-70 mph. There was no vibration, just a very loud bearing whine with a hint of slight grinding. The noise is more prominent when turning slightly right, and dissipates slightly when turning to left when at speed.
These are brand new bearings/hub. I torqued the spindle bolt to 134 lb-ft, and I noticed the original stake was well past the key channel so I had made a new stake down the lip of the nut a bit. Any suggestions of where I went wrong? Could I have torqued too much (used an old torque wrench, was rather imprecise) leading to excess noise?
Old 01-14-2013, 01:40 PM
Former User's Avatar
Default Re: Replaced rear wheel hub/bearing assembly very noisy
Is the splash guard bent and rubbing on the brake rotor?
Old 01-14-2013, 01:44 PM
redm3turbo's Avatar
did you pull the brakes/rotors?
Ive had a bolt back itself out before and become lodged between the rotor/caliper that made some loud noises. Granted it wasn't after a wheel bearing, however Ive also bought a brand new bearing, and installed a bad part.
Got to yank it apart to diag.
Old 01-14-2013, 01:48 PM
Master Detailer
98civdx's Avatar
You have to remove the rotor/caliper.
I agree with RonJ
Old 01-14-2013, 01:49 PM
TeeO's Avatar
I did put some pressure on it while trying to work the stubborn bearing race off the spindle. I'll get under tomorrow and check.
Old 01-14-2013, 01:57 PM
Easy fix, if so. And also very common source of wheel noise.
chris d
Suspension & Brakes
08-29-2016 02:04 PM
civic-steve-94
07-04-2011 12:19 AM
schpiel
09-17-2007 07:28 PM
AlekSir
09-05-2005 03:07 PM
vtecdc2
09-28-2003 04:34 AM
Quick Reply: Replaced rear wheel hub/bearing assembly very noisy
