EG Si Cluster - temp and gas gauges don't work - Is it possible to repair?
Old 10-18-2010, 10:12 AM
KeffenG's Avatar
Default EG Si Cluster - temp and gas gauges don't work - Is it possible to repair?
Is it possible to repair a cluster?
I have a cluster and the problem is that the gas milage and the temperature doesn't work. Is it possible to fix that or i just have to get another cluster?
Old 10-18-2010, 10:18 AM
I'm not Rick!
rick_rabies's Avatar
Default Re: EG Si Cluster's
clusters for egs are dirt cheap.
so when its cheap people 99% if tge time replace them.
but if you are good at micro soldering and desoldering you could find where there is burt resistors or compacitors and replace them
Old 10-18-2010, 11:22 AM
KeffenG's Avatar
Thanks. Do you know where you can find cheap real deal si clusters? Like any websites?
Old 10-18-2010, 11:36 AM
I'm not Rick!
ebay. junk yard or fs forums.
make a WTB add in the marketplace
Old 10-18-2010, 11:37 AM
Former User's Avatar
Default Re: EG Si Cluster - temp and gas gauges don't work - Is it possible to repair?
Have you ruled out bad wires and sending units for these two gauges?
Old 10-18-2010, 11:56 AM
KeffenG's Avatar
ric rabies- Thanks i'll check it out.
ronj@ht- honestly i dont know how to fix the gauges n i'm not sure if the wires are bad or not. but i do see some burnt resistor's.
MTarry
11
01-15-2013 06:46 PM
Yoitshector
09-21-2011 05:19 PM
JDM_WHR
10
06-07-2010 08:50 AM
hoophype84
11-12-2004 06:45 AM
o d i e e
11-05-2003 07:58 PM
Quick Reply: EG Si Cluster - temp and gas gauges don't work - Is it possible to repair?
