my DelSol Vtec wont pass smog
Old 12-11-2009, 08:17 PM
legendarypk's Avatar
Default my DelSol Vtec wont pass smog
i failed smog twice alrdy my del sol is 94 vtec(B16A3) cuz im having high HC and CO. i replaced new cat the air is a little bit better but Co is 7.00+ max is 0.55 and my HC is 300+ and max is 92.my car's engine light is not run. run strong. i think previous owner modified some stuffs inside the car. plzz tell me wat the problem is
people please tell me wat i can do and can someone hook me up with some smog test only station around bay areas please. and please send me a private message or aim me.
also... if nobody wouldnt tell me the tricks. i would sell my del sol for a cheap price too. there the link of my del sol
http://sfbay.craigslist.org/sfc/cto/1506023987.html
Old 12-11-2009, 08:20 PM
itsnotfast's Avatar
Default Re: my DelSol Vtec wont pass smog
Seafoam has good results. I've had good luck with that.
Old 12-11-2009, 08:24 PM
mechanics told me i might have fuel injector problems/o2 sensor/ EGR values/ stuffs like that
Old 12-11-2009, 11:03 PM
delsolproblems's Avatar
Just about any engine system not working properly can affect emissions. So, to get the best emissions possible, you need to check all of the systems. First make sure that all of the regular maintenance items are fairly new- air filter, fuel filter, oil filter, PCV valve, thermostat, gas cap, radiator cap, distributor cap and rotor, plugs and wires. Next, check and clean the grounds. Check your spark at all four wires to make sure your whole ignition is strong. Check the ignition and valve timing. Replace the timing belt and tensioner spring if they are old. Check the MAP sensor voltage to see if it is working properly and to check for vacuum leaks. Clean the TB, IACV, FITV and IAT sensor. You may want to get a new O2 sensor if it is old. Check the valve clearances. Finally, you should borrow a fuel pressure gauge from a parts store and check the fuel pressure. If you go through this entire tune up, you'll want to check/flush/bleed/top off your fluids to finish the job right even though most won't affect emissions. You can also check the compression but fixing that is, of course, a much bigger task than the tune up items listed here. GL
Old 12-12-2009, 06:45 AM
New User
izzy98ek's Avatar
Icon6 Re: my DelSol Vtec wont pass smog
ok first things first your check engine light is not on but your numbers are high ok so it sounds like your ecu may be chipped by chiping your ecu it alows the chip to delet some sensores witch is y your not throwing a check engine light also another reason you might not have a check engine light is someone may have taken out the bulb so
Old 12-12-2009, 06:59 AM
ok the check engine light is on and go off by itself just like regular normal cars. mechanic i no said my car is rich taking extra gas stuff. so he said it most likely be fuel injector.
mynameisrainman
19
08-01-2016 09:32 PM
dippy
11-01-2008 12:52 AM
B18Redline
03-17-2006 09:48 AM
B18Redline
10
01-04-2006 04:43 PM
theFORUMman
15
11-08-2004 03:47 PM
Quick Reply: my DelSol Vtec wont pass smog
